October 24, 2026, 10:06:46 PM
| | |-+  fan sensor temp
Author Topic: fan sensor temp  (Read 10027 times)
« on: August 03, 2008, 09:26:33 PM »
hi anyone found a fan temp sensor the comes in earler ,mine doesn't come in till 2/3 rds off the way up almost , there was a web site im sure it was in usa that does a switch to your spec or a lot lower than
standard but was about ?45 any body used an oe sensor from an other vehicle that lower
jay
« Reply #1 on: August 04, 2008, 08:28:31 AM »
Just out of interest, why do you want the fan to come on at a lower temperature? The book says the fan should come on between 90 & 94deg/C. The thermostat should start opening between 83 & 87deg/C and be fully open by 95deg/C. If you bring the fan on earlier, the engine's just getting up to operating temperature and then the fan's trying to cool it down.
« Reply #2 on: August 05, 2008, 07:04:18 AM »
This is why you need to get a thermostat that opens earlier. for example the one from some Fiat Ducato 2,5D and then fit it inside head as it is only an insert
« Reply #3 on: August 09, 2008, 08:29:36 AM »
cause the fan come's in to late when its worryingly hot get the fan to come in just before half way and
more fuel efficent  with out getting to hot...
« Reply #4 on: August 09, 2008, 09:20:40 AM »
Are you sure it's not the thermostat not opening too late? If the water thermostat opens late, you only get hot water in the radiator when it's too hot and the fan will only come on when the radiator has hot water flowing through it.  Connect the fan wires together so it's on all the time and if the engine still rans a bit hot then you should change the water thermostat.
