October 23, 2026, 09:36:41 PM
| | |-+  electric fuel pump ???
Author Topic: electric fuel pump ???  (Read 17809 times)
mccabe131
« on: January 08, 2009, 08:54:19 PM »
Hi guys any advice on changing my 131 racing from manual engine mounted fuel pump to an electric one. My engine is running twin downdraft carbs. All help and advice appreciated  Huh
Mick McCabe Kilkenny 1979 131 racing, 1980 1993 Fiat tipo sedicivalvole, 1989 1990 fiesta xr2i, 1991 sierra cosworth 4x4,1983 M B 300 GD,
« Reply #1 on: January 08, 2009, 10:21:29 PM »
I too have twin carbs (45 DCOE sidedrought) so the mechanical pump was probably not going to be able to keep up the supply! I have a Facet "Fast Road Competition Silver Top" pump which is meant to be good for engines up to 170bhp. My engine is only 155bhp so doesn't need anything more. In fact I changed the pump just about a year go and you can read that thread at http://131mirafiori.com/smf/index.php?topic=736.0. Facet make several versions of this pump from "Standard" to "Fast Road" to "Full Race".
The pump is fitted in the boot near the fuel tank.
Ideally, you should also fit an inertia cut-off switch so the pump will stop pumping in the case of a sudden impact i.e. an accident. If the car is in an accident, you don't want the engine to be off and the pump to be still pumping fuel everywhere. I have the inertia switch mounted inside the rear quarter panel. You'll also need to get a blanking plate to cover the hole left behind by the old mechanical fuel pump. The plates should be readily available from Fiat as several twin-cam engined cars had electric fuel pumps but it's a simple enough plate to make.
« Last Edit: January 08, 2009, 10:23:22 PM by Thotos » Logged
« Reply #2 on: January 08, 2009, 11:17:13 PM »
I too have an electric fuel pump on one of my 131s to fill my twin 40 dellortos. Spookily it is in the same place as yours Theo. I don't yet however have the inertia switch or blanking plate, my old mechanical pump is still in place. I guess I will get round to it sometime!
« Reply #3 on: January 09, 2009, 01:58:54 AM »
A simple solution is a relay wired in to the oil pressure switch circuit, a simple timer to allow current to the pump when ignition is turned on overcomes starting issues. It can also save an engine if you lose oil pressure.
« Reply #4 on: January 09, 2009, 02:13:06 AM »
Yes a lot of cars use a relay energised by the oil pressure switch to power the pump. As Tas131 correctly said a timer is used to run the pump for a while when the ignition is turned on or a second relay can be used connected to the starter solenoid circuit so the pump runs while the engine is being cranked.
« Reply #5 on: January 09, 2009, 02:22:34 AM »
Are those hints of Orange in the boot Thotos?
I think weve been here before!  Roll Eyes
« Reply #6 on: January 09, 2009, 11:03:32 AM »
Yes definite hints of orange and yes we've been though this before  Grin My car was restored in 1995 by the previous owner using a donor shell from an orange Sport and as many new panels as he could get (doors, wings, bonnet, bootlid etc). So maybe I can join the "Orange Boys" even though my orange car is wearing a disguise  Grin Grin
« Reply #7 on: January 09, 2009, 12:25:34 PM »
Any one can join the orange boys, as long as you have an orange car Grin
and Theo as your car IS Orange! your a welcome member Cheesy
« Last Edit: January 09, 2009, 12:28:01 PM by parrish » Logged
« Reply #8 on: January 10, 2009, 12:33:09 AM »
aboout those fuel pumps...
i think i read somewhere (fiat 132 service book probably) that standard fuel pump delivers 86l/h at max rpm (6.000?). why do you all think it ain't enough fuel for twin carb setup? with single carb at least 80% of fuel goes straight back to fuel tank anyways...
« Reply #9 on: January 10, 2009, 09:28:08 AM »
You are probably right that the standard fuel pump in good condition can deliver enough fuel but the advantage of the Facet electronic pumps is that they deliver a steady supply of fuel while the mechanical pumps deliver 'bursts' of fuel.
« Reply #10 on: January 11, 2009, 11:06:36 AM »
My super fitted with bored out chokes on twin 40 idfs and high lift cams ,still used mechanical pump
 with  no problems
jay
mccabe131
« Reply #11 on: January 19, 2009, 01:46:28 PM »
Thank you all very much for the help very much appricated  Smiley Smiley Smiley
