October 24, 2026, 05:58:09 PM
| | |-+  Fiat 131 Centre bore.
Author Topic: Fiat 131 Centre bore.  (Read 11396 times)
« on: February 08, 2009, 02:33:31 PM »
Does anyone have the Centre bore dimensions for the axles of a 131?
ive been told its 58mm can someone check for me.
Steve.
« Last Edit: February 08, 2009, 02:35:21 PM by parrish » Logged
« Reply #1 on: February 08, 2009, 04:24:12 PM »
Hi Steve its 45mm
« Reply #2 on: February 08, 2009, 05:15:00 PM »
Seriously!
I thought it was 58mm!
« Reply #3 on: February 08, 2009, 06:30:30 PM »
Steve the pipe where the half shaft goes through is 45mm inside diameter, any other measurements you need i have cos i cut up rear axle this week, just ask.
« Reply #4 on: February 08, 2009, 09:14:33 PM »
Sorry Sid,
i was unclear in my first request.
Its the centre bore for the wheel im looking for.
The collar of the wheel sits around a protrusion from the axle, this locates and carries the weight of the wheel.
« Reply #5 on: February 09, 2009, 12:15:42 AM »
center hole on the wheel should be 58.2mm
if bigger - get yourself some adaptors made, if smaller - get it machined to 58.2
