July 29, 2026, 09:53:32 PM
| | |-+  wheel spacer thickness and wheel offset
Author Topic: wheel spacer thickness and wheel offset  (Read 14249 times)
USA131
« on: September 14, 2009, 01:38:18 AM »
All,
Any
Any ideas what the wheel spacer thickness i was for the 131 Abarth. Any guesses as to the wheel offset? Huh
USA131
« Reply #1 on: September 14, 2009, 12:01:14 PM »
Hy,
for which Abarth,  131 Stradale or 131 Abarth Gr.4 ?
Enzo Roll Eyes
USA131
« Reply #2 on: September 14, 2009, 02:40:58 PM »
Stradale please.
USA131
« Reply #3 on: September 14, 2009, 05:30:38 PM »
Stradale please.
USA131
This is the Original description from the Stradale Wheels:
Cromodora CD 68 - specifications
Rim material: Magnesium
Rim width x diameter (inches): 7x15
Offset: 0
Bolt pattern: 4x98
Weight: 6,6 kg
Year: 1976
Manufacturer part number:.........
Cars: Fiat 131 Rally Abarth
Pic's from Original Stradale Rims.
Enzo Wink
Gremlino
« Reply #4 on: September 14, 2009, 08:32:33 PM »
And here is the wheel spacer and thickness......
Signature has gone Kaput!
USA131
« Reply #5 on: September 15, 2009, 03:42:51 AM »
Thanks so much!! Wink
USA131
« Reply #6 on: September 15, 2009, 05:41:58 AM »
I used 50mm on the back axle but it was standard 131 racing axle(stiff) not abarth. On front i made the suspension wider for 55mm to each side but i have not used spacers but made longer wishbones.
« Reply #7 on: September 15, 2009, 08:27:27 AM »
yes Thomasz,
i use 50mm in Front (100 mm overall) and 70mm on back (140mm overall Original 131 Racing axle)
with the CD 68! and 195/50/15 tyres.
Look Pic's
Enzo Wink
« Last Edit: September 15, 2009, 08:31:32 AM by Fiat 131 Abarth#2 » Logged
« Reply #8 on: September 15, 2009, 05:03:32 PM »
Correct me if im wrong but the any wheel fitted onto a Fiat is 'Hub Centric' which means that the wheel is located centrally on the centre of the hub. The bolts do not line align the wheel centrally, make sure any spacers locate on the centre of the existing hub and offer another centre for the wheel.
Flat faced spacers will not do.
« Last Edit: September 15, 2009, 05:05:08 PM by parrish » Logged
