October 21, 2026, 12:15:38 AM
| | |-+  WANTED straight Manifold 40's
Author Topic: WANTED straight Manifold 40's  (Read 17125 times)
« on: November 07, 2009, 04:39:15 PM »
As you may or may not know in currently fitting EFI/ECU to my 131 sport.
Ive fitted the Throttle bodies to the 'Offset' manifold and i have a small problem.
Not enough room between bulkhead and fuel rail, so im looking for a 'straight' manifold.
Can anyone help?
« Last Edit: November 07, 2009, 04:45:32 PM by parrish » Logged
« Reply #1 on: November 07, 2009, 08:06:07 PM »
Can't you turn the fuel rail input over to the other side? Seems to be enough room especially if you use a 90 degree fitting. Aren't you supposed to have a 'common rail' feed on this system as on twin carbs? (i.e. connect the fuel feeds together).
« Reply #2 on: November 07, 2009, 08:33:16 PM »
Parrish ,  looks very good indeed !!!
RE manifold , The tilt was to avoid the  block mounted distributor , 0of you put one in the head you will be able to put either a straight or a forward tilt manifold which will give you plenty of space.
I wish I could do it on my LHD .... Cry Cry Cry Cry
M
« Reply #3 on: November 07, 2009, 08:52:09 PM »
Thotos,
Yes its a common fuel rail that runs a return to the tank hence the connections at both ends, one will be an inlet the other a retun to the swirl pot,  its shown mocked up in the photo without the middle rail.
Miro,
exactly what im after, do you know where i can get one? ive fitted an ECU so no distributor at all.
« Last Edit: November 07, 2009, 08:54:56 PM by parrish » Logged
« Reply #4 on: November 07, 2009, 09:00:27 PM »
So why not simply change the fitting near the bulkhead with a 90 degree one for the return pipe?
« Reply #5 on: November 07, 2009, 10:37:39 PM »
will a ritmo 130tc manifold do?
« Reply #6 on: November 08, 2009, 07:39:15 AM »
Theo,
the fitting at the end of the fuel line appears to be non removable, i am trying to get hold of another fuel rail to see if it can be done, but even then clearence is minimal. However i may have to see what i can do along those lines.
Djape,
carburettor connections look wrong.
« Reply #7 on: November 08, 2009, 07:58:35 AM »
they're exactly the same as on you offset manifold
« Reply #8 on: November 08, 2009, 08:02:51 AM »
Steve get a nice stainless steel one made up.
« Reply #9 on: November 08, 2009, 10:29:57 AM »
130 Abarth one should fit as they only don't suit a normal 131 as the block mounted distributor usually gets in the way
« Reply #10 on: November 08, 2009, 10:44:48 AM »
djape,
on second looks you look right.
any chance of a photo from the carburetor flanged end?
if it looks good, do you want to sell it?
« Reply #11 on: November 08, 2009, 11:29:00 AM »
a friend of mine owns this particular manifold. its 42mm dia. on the carbs flange side. since the photo was taken, it's been cleaned from grith and gasket remains. he wants 130e for it. i don't need it since i can't use it on any of my cars. when mounted on a rwd car, it gives a tilt of aprox 10 degrees up from horizontal to the carbs
« Reply #12 on: November 08, 2009, 01:46:26 PM »
djape,
no its definetly different, imagine the manifold on the engine, then look at the position of the top carb mounting points in my photo, they need to be wide apart, this manifold would put the top carb mountings close together?
« Reply #13 on: November 08, 2009, 04:40:30 PM »
i don't have it with me, as i said, it's my friends and its in his garage, but one thing i can say for sure is that it was on ritmo 130tc with standard twin sidedraught solex 40 carbs. try to find some photo of ritmo 130 engine bay for reference
« Reply #14 on: November 09, 2009, 12:56:42 AM »
Parrish,
I have seem one but do not have one.
I will check with some friends, who might have a spare.
I have an LHD and have to use IDF's  due to the vacuum boost location, so I a using standard waffle manifold.
M
