July 27, 2026, 06:02:36 PM
| | |-+  Fiat Argenta Steering Parts
Author Topic: Fiat Argenta Steering Parts  (Read 11275 times)
Fiat Nut
« on: November 09, 2009, 12:50:10 AM »
Hi, I am looking for a full set of steering parts for an Argenta RHD - Box, Idler and Pump etc.  Would anyone out there have them stashed away or still on an old body? - Thanks Smiley
« Reply #1 on: November 09, 2009, 08:08:28 AM »
I have the power steering pump from 131 supermirafiori mk3 which will be the same as your argenta.
« Reply #2 on: November 11, 2009, 02:17:27 PM »
Graeme, pictures of pump for you, this has sat in a draw in the shed for 15 years or so but it still had some fluid in it, turned the pulley and it works fine. David
« Reply #3 on: November 11, 2009, 02:18:06 PM »
« Reply #4 on: November 11, 2009, 02:23:52 PM »
Fiat Nut
« Reply #5 on: November 12, 2009, 01:27:11 PM »
Looks just like to one - thanks.  Where, when, how?
« Reply #6 on: November 12, 2009, 01:42:58 PM »
correct me if i'm wrong, but the steering "head" (rack and pinion or whatever it's called) is not the same for LHD and RHD cars?
« Reply #7 on: November 12, 2009, 03:09:01 PM »
djape, as you say 132 is steering box not rack & pinion but this is just the power steering pump which on all the 2000 ones I have seen is the same, not sure on earlier 132s so couldnt comment.
« Reply #8 on: November 12, 2009, 04:59:56 PM »
pump is the same as far as i know, but steering box (thanx) is probably different for LHD and RHD. i have several steering boxes for LHD cars
Fiat Nut
« Reply #9 on: November 12, 2009, 06:03:29 PM »
You're right, the 132/Argenta was a worm & roller system, as far as I can tell the 132 2000 introduced in 1977 came with the power steering version - the 1600's & 1800's prior were not.  The steering box and idler are handed (pity about that djape1977!).  The pump from David is universal.
