September 15, 2026, 05:59:44 AM
| | |-+  centre propshaft mount
Pages: [1] 2 3 ... 6 Go Down Print
Author Topic: centre propshaft mount  (Read 94619 times)
« on: November 10, 2009, 05:49:09 PM »
I have ordered centre propshaft mount, bearing and nut for 131 from a Lada spares place of the net and for all three parts including post to Uk its $49.80 US dollars thats ?29.84p, not sure where they are based ? but they want paying in dollars, keep you informed how it goes..........
« Last Edit: November 10, 2009, 07:38:24 PM by david » Logged
« Reply #1 on: November 10, 2009, 09:51:02 PM »
finally! someone besides me who has the gut to put lada parts on 131! report of progress
« Reply #2 on: November 10, 2009, 09:56:14 PM »
Its Russia which is what I thought but they sound legit and dont think I will have to pay customs as parts are under ?18 ?  go to www.ladaparts.ru    I suspect the centre mounts advertised on ebay for ?39.95p probably originate from here anyway ?
« Last Edit: November 10, 2009, 10:10:16 PM by david » Logged
« Reply #3 on: November 10, 2009, 10:13:43 PM »
There is/was a Lada specialist up here near me. I wonder if he stocks these parts?
« Reply #4 on: November 10, 2009, 10:15:26 PM »
I hope not ive just ordered them from Russia Cheesy
« Reply #5 on: November 10, 2009, 10:29:51 PM »
Can't find him on the net. I think Eugene will know.
« Reply #6 on: November 10, 2009, 11:27:38 PM »
Guys ,
Let's keep this Lada thread going , maybe we will build a database of sorts which Lada parts can be used as replacements for our Fiats.
« Reply #7 on: November 10, 2009, 11:43:53 PM »
Problem is the Lada was a patent built Fiat 124 and Lada used there own engine and box so you are very limited for 131 but a lot better off if you own a 124 I would guess
« Reply #8 on: November 10, 2009, 11:49:44 PM »
I actually have  124 spider , and one o my front suspension arms is from a Lada . It only required welding spring seats differently.
« Reply #9 on: November 11, 2009, 12:59:03 AM »
actually, engine and gearbox are a compilation of several fiat engines and gearboxes. for instance, bellhousing for TC engine from fiat 125 will bolt straight on to a lada gearbox, which is very simmilar (same?) as fiat polish 125 gearbox, and than straight onto a fiat's donut. also, U joints are the same.
it's a diference between lower front suspension arm for fiat 124 sedan and spider. if you took the suspension arm from 124 sedan, you'd have the same problem.
rear suspension of lada is 90% same as on 131. suspension arms and bushings from lada can be used on 131.
rear coil springs for lada are the same lenght and diameter as for 131, but are available in diferent load capacities, therefore giving a choice of three diferent stiffnes/height combo's. one could also take a hard spring for lada and shorten it by a coil or two and get a hard stiff 131 rear end. bog standard rear spring for lada is the same load capacity as for 131.
engine mounts on lada and 131 are the same. gearbox mount for lada can be fitted to a 131/132 gearbox with 5 minutes modifying job.
oil filters are the same.
rubber seal surrounding the doors and the boot (sorry guys, don't know the name of the part) is the same on 131 and on lada.
rear window winders on 4dr 131 are the same as on lada.
want me to go on?
bolger
« Reply #10 on: November 11, 2009, 07:53:23 AM »
Sure, go on.
« Reply #11 on: November 11, 2009, 08:19:35 AM »
The parts I ordered as of list above are  A) central prop mount  2101-2202080  $12 (?7.17p)  B) bearing for same 28042320  $8.80 (?5.25) and C) nut  2101-2202105  $2 (?1.19p)  so a Total of  ?13.61p  for parts and you can use paypal, the rest is post, they say two weeks for delivery but I think thats a bit on the optimistic side but we will see ?
« Reply #12 on: November 11, 2009, 11:33:57 AM »
Here are the details Dave.
Alan Bird is his name and he is in Penrith.
E-mail address is   alan@lada.co.uk   Tel 01768779794.
He has recently started a e-bay shop of his own
http://stores.ebay.co.uk/LADA-UK-LTD .
Alan is like Yagmur,honest,prompt and efficient.He is also a farmer,and sometimes it can be difficult to get him on the phone,but keep trying and you will get him.Like Yagmur,i have yet to hear anyone say anything bad about Alan.Eugene
Yagmur
« Reply #13 on: November 11, 2009, 02:52:33 PM »
Thanks for your nice words Eugene,
But why you are talking about Lada parts and modifiying them to fit 131s.
I have almost every part and cheap prices.No need modifying,high quality parts.etc...
Djape,you are talking about making the engine mounts,window rubbers,etc,I have these parts at the stock.
« Reply #14 on: November 11, 2009, 02:57:47 PM »
These Lada parts same as 131
Pages: [1] 2 3 ... 6 Go Up Print
