October 24, 2026, 06:49:04 PM
| | |-+  centre propshaft mount
Pages: 1 2 [3] 4 5 6 Go Down Print
Author Topic: centre propshaft mount  (Read 95923 times)
« Reply #30 on: November 13, 2009, 05:59:51 PM »
David how do you remove the lock barrel from a 131 door handle? do you know how?
« Reply #31 on: November 13, 2009, 06:07:19 PM »
haven't tried that, but it could be the case since keys are the same as on old fiats
« Last Edit: September 11, 2010, 07:06:19 AM by djape1977 » Logged
« Reply #32 on: November 13, 2009, 06:13:57 PM »
when you have the door handle off the car the back cap has a pin, this can be corroded with age now but drift this out using the stem from a suitable sized rivet, using a socket underneath to push the pin into and the cap will come off revealing the centralising spring, remove this and as I recall the barrel will push out through the front
« Last Edit: November 13, 2009, 06:17:17 PM by david » Logged
« Reply #33 on: November 13, 2009, 06:17:25 PM »
Thanks Davis i was baffled how to do this & have new handles off a super & want to put the locks into a racing handle.
« Reply #34 on: November 13, 2009, 06:46:19 PM »
picture of parts Nick...
« Reply #35 on: November 13, 2009, 10:21:40 PM »
linkage for brake balance valve - should be the same as on 131
brake master cylinder - as i said before, same as for fiats, including the bits inside. rebuild sets still available for lada
rear brake cyl. - still haven't changed those on my 131 so i don't know if theyre the same
« Reply #36 on: November 13, 2009, 10:49:11 PM »
From memory the 131 has a much simpler arrangement for the rear brake load valve with a rod that goes through a bracket on the trailing arm mounting.
« Reply #37 on: November 13, 2009, 10:51:33 PM »
i might be wrong. perhaps then its as on 125 or 132? beats me, i know i saw that arangement somewhere recently
« Reply #38 on: November 14, 2009, 12:15:16 AM »
Also note that the door handles(outside) on my Nivas are the same on the series one 131.I am pretty sure that the handles on the sport are the same Undecided,but i am open to be corrected  Roll Eyes.Eugene
« Reply #39 on: November 14, 2009, 07:32:39 AM »
As stated fitment for load valve is different being a straight bar with a loop in it but valve its self is the same as I was told, just fit 131 bar
« Reply #40 on: November 14, 2009, 07:45:52 AM »
excellent David, thanks again.
« Reply #41 on: November 14, 2009, 08:16:31 AM »
djape, this is 131 cyl so looks the same and no reason why it wouldnt be I suppose
hammerbeirne
« Reply #42 on: November 14, 2009, 05:09:46 PM »
Is there a difference between a mk 1 and mk 2 door lock that is the bar that connects the locking button on the inside of the door is it shorter on a mk 1?
« Reply #43 on: November 14, 2009, 07:53:18 PM »
Do you mean the rod between the back of the lock and the catch on the door ? if so the mk2 had a totally plastic one and as I can remember the mk 1 was a metal rod threaded at either end to which plastic caps screwed on which had the same size hole to clip on and I have seen mk2s with mk1 type so they must interfit and the doors are same
hammerbeirne
« Reply #44 on: November 14, 2009, 08:14:56 PM »
No David i mean the part that the inside lock button screws onto its a metal bar
Pages: 1 2 [3] 4 5 6 Go Up Print
