July 30, 2026, 10:42:08 AM
| | |-+  k&n 57i high flow intake
Author Topic: k&n 57i high flow intake  (Read 29964 times)
« on: December 13, 2009, 12:15:48 AM »
Fitted my new k&n air filter today. Took her out today with the new k&n filter fitted. Very easy to install only thing i had to do was turn down the idle screw as after fitting it engine was revving high as hell.So for all who still run the single carb twin choke set up its worth spending the money. The part number custom racing assemgly No is 56-9032 from k&n uk.
Sounds good and feels more responsive.
And to all you 131 ers who run the twin 40s and 45s yes i am jelous but this set up will do meantime till i can afford.
Incase any one is intrested contact details follow.
K&N
John street
Warrington Cheshire
WA2 7UB
UK 01925636950
selem
« Reply #1 on: December 13, 2009, 02:44:20 AM »
can you upload a photo how its look like.
thanks
fiat 131S
« Reply #2 on: December 13, 2009, 07:43:38 PM »
pics pics pics pics please!!
« Reply #3 on: December 13, 2009, 10:21:38 PM »
Just got online so will take pictures on monday eavining and post them about 8pm...
« Reply #4 on: December 13, 2009, 10:24:02 PM »
good man looking forward to seeing!"
« Reply #5 on: December 13, 2009, 10:55:22 PM »
On my first post on this subject i wrote single carb twin choke set up
I should have put single carb auto choke set up.
Just incase any one pionts out the mistake.....................
« Reply #6 on: December 14, 2009, 05:43:49 PM »
As requested Sid & Selem.
K&N 57i high flow for single carb set up
« Reply #7 on: December 14, 2009, 05:50:00 PM »
More pics...
paulcas
« Reply #8 on: December 14, 2009, 08:17:19 PM »
nice looking K&N, bet it sounds good too....
« Reply #9 on: December 15, 2009, 12:47:08 AM »
looks great good luck with her, i read on the other post that your carb is 32 adf, should a sport carb not be a 34 adf? sure someone will know, i have twin delorto 40s
« Reply #10 on: December 15, 2009, 02:56:41 AM »
What did you do with the crankase breather pipe?
« Reply #11 on: December 15, 2009, 05:30:38 PM »
On the K&N I had it attached to the baseplate for the filter. I can't quite remember but I think this could have been a modification caried out by the previous owner of the filter Grin
Currently I run twin 40 Dellortos with K&N filters and the breather is vented to the open air through its own small filter.
« Reply #12 on: December 15, 2009, 07:31:52 PM »
i had the same one 20 years ago ... the other one i had one a replacement eliment k/n and cut all
 the sides out of the orginal filter case ..breather pipe allways went in to a catch tank,large cider can in my case ,you don't want dirty air going in to slow you down
there still on ebay
http://cgi.ebay.co.uk/K-N-Air-Filter-Fiat-131-2-0-1978-1984-E-2670_W0QQitemZ360172171471QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item53dbef30cf
« Last Edit: December 15, 2009, 10:05:02 PM by jasonh131 » Logged
« Reply #13 on: December 15, 2009, 08:52:28 PM »
Drilled a 9mm hole in base plate and squeezed the breather pipe through. Works fine..
« Reply #14 on: December 15, 2009, 09:55:17 PM »
Yes that works but as Jason said you are putting dirty oily air into the engine. What did you do with the smaller 6mm tube that goes from the air filter housing to the bottom of the carburettor?
