August 28, 2026, 09:46:43 PM
| | |-+  suspension coil springs
Author Topic: suspension coil springs  (Read 21818 times)
« on: March 29, 2010, 09:45:08 AM »
i know someone that got a set of springs made here & the feedback is excellent quality & price, ok lads so no more where do i get springs made?
http://www.coilsprings.co.uk/index.htm
« Reply #1 on: March 29, 2010, 01:14:03 PM »
I asked did they have the specifications for Fiat 131 sport & here is the reply
YES WE HAVE THE SPEC.
 1 CAR SET-ANY LENGTH/RATE-WILL COST ?160+VAT. DELIVERED. 20 WORKING DAYS FROM RECEIPT OF ORDER +CHEQUE.
NEIL  SATUR @  POWERCOIL
« Reply #2 on: March 29, 2010, 06:24:02 PM »
?40 per spring sounds like a good price. Good to know springs are readily available to order Grin
« Reply #3 on: March 29, 2010, 07:33:01 PM »
i wish i had known about them before i got my celica springs which cost $600 usd from america
« Reply #4 on: March 29, 2010, 07:41:49 PM »
At least you won't have to fork out that much again. Perhaps we should have a way of storing these useful web addresses on the forum so the next time a member needs a spring they know where to look.
I wonder if they have the specs for Simon's Abarth?
« Reply #5 on: March 29, 2010, 08:11:18 PM »
Dave i reckon they would be able to sort Simon out with new spring no problem & thats a good idea about storing web addresses "Theo!!"
« Reply #6 on: March 29, 2010, 10:39:18 PM »
I think it's a excellent idea Dave.Would save on a lot of unnecessary posts. ::)Eugene
« Reply #7 on: March 30, 2010, 01:18:52 AM »
Sid,
I wanted to post the text below ( which I will anyway) , but now know where to turn for springs ....
Will let you know the result  Grin Grin Grin
"Guys,
I am am however having a problem with the springs:
Both rear and front springs have a large ( old style) internal diameter. In addition the front strut housings have grease nipple on its side effectively forcing the large spring diameter. ( We estimate that that safest would be 100mm inside diameter of the spring . The rear can probably accept smaller diameter spring , but not less than 70-80 mm.
I actually would like to have the rear of a big diameter as in the original ( does anybody know the exact Stradale/Corsa rear and front spring internal diameters ?)
My knowledge of the springs is marginal. I have dug up Original 131 Abarth Stradale data on the springs. They should be:
FRONT
Fiat (Abarth) part number: 4335641
Height of spring under load of 3156 + / - 127 N (322 + /- 13 kG) = 270 mm
Minimum load to compress it to the height of 194 mm = 4459 N (455kG)
REAR
Fiat (Abarth) part number: 4151719
Height spring under a load of 2793 +/- 127 N (285 +/- 13 kG) = 310 mm
Minimum load for the height of 232 mm = 4067 N (415kG)
The problem is that current most current catalogs list them either by application ( no use ) or by uncompressed length and diameter rate in (N/mm) and weight. This is totally useless, or at least not easily translatable.
Does anyone know how to translate the original Fiat data or what springs cane be used (modified as replacement for 131 Abarth).
Does anybody know what Fiat springs could be used modified to fit ?
Miro"
« Reply #8 on: March 30, 2010, 02:09:41 AM »
Eugene,
I have a suggestion : why don't you put one more category called "links " and enter links to such places like this one. However entering links should entered only by administrators ,  otherwise we will get a lot of junk in it  and it will lose its sense !
PS:  I have written to them asking about Stradale and Gr4. springs. Will post the result.
« Last Edit: March 30, 2010, 02:13:55 AM by miro-1980 » Logged
« Reply #9 on: March 30, 2010, 12:17:12 PM »
OK guys, a new section called Connections  has been added to the forum. Use it to post links to other websites and suppliers such as the spring people - Nick, please be the first poster in the new section. Miro, sorry, I don't like the idea of "administrators only" section as that creates more work for the administrators including me and I don't like more work!  Wink Grin We can moderate the section retrospectively and remove  any posts that don't belong there. Please keep the posts in the Connections section short and precise and avoid replying to messages in that section.
« Reply #10 on: March 30, 2010, 01:13:00 PM »
Just did Theo, well done this will be a good section & hopefully will be able to help people get the sought after parts.
« Reply #11 on: March 30, 2010, 03:00:17 PM »
Thanks Theo Wink.I thought you might have said no ::)Eugene
« Reply #12 on: March 30, 2010, 03:18:49 PM »
Why would you think that Eugene!  Huh Wink
« Reply #13 on: March 30, 2010, 03:44:13 PM »
I can tell you - Ask me ...ask me!!!  Grin Grin Wink
« Reply #14 on: March 30, 2010, 03:50:16 PM »
OK, I'm asking, I'm asking....  Huh  Wink
