August 27, 2026, 05:12:19 PM
| |-+  Down to Business (Moderator: Admin)
| | |-+  distributorless ignition system
Author Topic: distributorless ignition system  (Read 20077 times)
so cal mark
« on: April 13, 2010, 03:36:47 AM »
I now have the new distributorless ignition systems. The trigger unit replaces the distributor and mounts in the spot where a block mounted distributor would mount. Simple plug and play installlation, very easy to set timing. I'm posting a link to an introduction video. The production systems have the harness routed under the intake manifold and around the back of the engine rather than over the top as in the video.
http://www.youtube.com/user/1565socalmark?feature=mhw5#p/u/4/OiCMZ3X0Y58
« Reply #1 on: April 15, 2010, 04:16:11 AM »
Mark,
am i buying a custom manifold from you Grin
If so why dont you post a link to your www so all can see your products? i know your a 124 man but a lot of the products cross over to the 131 range.
If ive got the wrong Mark, sorry.
Steve (Currently at work in Qatar)
« Reply #2 on: April 17, 2010, 11:51:39 AM »
Hi Mark,
OK so i dont read all the threads all the time Embarrassed
I see you have intoduced yourself in the 'Introductions' thread  Embarrassed
so cal mark
« Reply #3 on: April 17, 2010, 08:56:13 PM »
thanks for the comments Steve, I'll add the www into my signature
selem
« Reply #4 on: April 21, 2010, 09:55:07 AM »
Hi Mark,
hi Parrish,
sorry ask out of topic.
may I know what color code of yours orange 131 sport. I want try onto my 131s how its look like Smiley
hope you dont mind,
thanks,
selem
fiat 131S
gunobla
« Reply #5 on: April 21, 2010, 05:38:27 PM »
How much does the system cost
so cal mark
« Reply #6 on: April 30, 2010, 05:06:15 AM »
the complete system is $550;
so cal mark
« Reply #7 on: May 05, 2010, 02:31:45 AM »
here is a new video showing the ignition system and dual carb intake. 131 header is in the works and I'll post that when it's ready
http://www.youtube.com/watch?v=Nxu_GPWJd0g
gunobla
« Reply #8 on: May 05, 2010, 07:46:42 PM »
I have just ordered one of these ignition systems from Mark and it's on the way now.   He is very good and prompt.   You get immediate responses to your emails etc and I can't wait to install it.
« Reply #9 on: May 05, 2010, 11:48:22 PM »
So cal mark.
Ibought a weber twin 40 idf set up on a genuine Fiat waffle manifold it is missing the linkages but apart from that its mint.
Problem is it does not fit the 131 2000 tc as the dizzy is in the way so i have 2 choices find a head with a cam mounted dizzy and a blank to block of the block mounted dizzy i have on.
So what would be the better/cheaper option finding a new head and blank !!
Or fitting that system.
Or just selling the idf 40s and getting 2nd hand side draught 45s with suitable manifold which will not affect my block mounted dizzy.??
Your system does seem good but im looking for the easy option.
so cal mark
« Reply #10 on: May 06, 2010, 03:54:06 AM »
well, in my opinion the easiest route would be to install my ignition kit. It certainly is less work than either of your other choices. It literally takes about 15-20 mins to install my kit, and the performance is phenomenal. Swapping the head or cam box or carbs takes a bit longer than that
