July 26, 2026, 09:41:29 PM
| | |-+  Wanted: 131 rollcage and limited slip diff
Author Topic: Wanted: 131 rollcage and limited slip diff  (Read 15523 times)
zolmio
« on: June 12, 2010, 12:34:48 PM »
Does anyone have rollcage and/or limited slip differential to sell for 131 racing volumetrica abarth?
Prefer original or OMP  bolt on cage.
« Reply #1 on: June 12, 2010, 07:04:11 PM »
What happened, to much wheel spin, or stripped the teeth of the pinion?
  I'd use a ford Hybrid axle with plate type LSD, but others have there own ways depending on where in the world you are.  If you just change the Slipper, your still left with a weak CWP, with the same parts that disintegrate.
         Roger......... Cool
P.S  call if you want the axle spec.
zolmio
« Reply #2 on: June 13, 2010, 08:09:35 AM »
Thanks for your reply.
Using the car mostly in regularity rallies it needs more grip on gravel and snow.
Hybrid solution is unfortunately not acceptable for cars FIA-homogolation, what is needed in international rallies.
« Reply #3 on: June 13, 2010, 10:34:40 AM »
Are you aware that the Pinion strips its teeth, often.     Do you mean the axle has to be the same housing, or all of it?    If you have to keep the CWP you will be wasting you entry because its going to break.   One of mine was only behind a 1438 OHV, still broke, and that with NO side steeping, or snatching the clutch, just normal fast driving
One of the chaps was saying you can get the CWP from a 125 I think it was, maybe use a Lada Slipper, I cant remember.
        Roger.....
« Reply #4 on: June 13, 2010, 10:56:24 PM »
cadbury dairy milk available in most sweet shops, same material as the cwp
« Reply #5 on: June 13, 2010, 11:54:04 PM »
    A Men, Ant that the truth Grin
« Reply #6 on: June 14, 2010, 07:21:54 AM »
Hello zolmio,
look here for Slip-Diff! T.260 COPPIA FRENATA DIFFERENTIAL 131 2000
http://www.colotti.com/engl/company.htm klick on "Coppia-Frenata"
And rollcage i prefer HEIGO
http://www.heigo.de/ASP/index.asp?PID=&ACT=102&WKA=219&WKC=1&CAT=2&SCAT=Fiat
Enzo Wink
zolmio
« Reply #7 on: June 14, 2010, 01:02:47 PM »
Enzo, thanks about your nice advises. Do you think, that Heigo cages are FIA approwed?
And how about your rallycar, is there LSD?
Greetings
Zolmio from Finland
« Reply #8 on: June 14, 2010, 04:00:09 PM »
Hello Zolmio,
yes it's with DMSB/ONS Zertifikat: Homologation: FIA-ALL J-FIA Bestimmungen gem. Anhang J Art. 253, oder ASN RAC Homologation.
my LSD is still Original Racing with this Look!
http://www.bacciromano.com/index.php?p=prodotti&l=ita&cat1=25&cat2=92&mar=4
and my next project look's like this look pic.
Enzo Wink
zolmio
« Reply #9 on: June 14, 2010, 07:33:41 PM »
OK, you are making Independent Rear Suspension  like 131 abarth (stradale and gr.4).
My racing abarth will be like gr.2 and must use solid axle.
When your next project (IRS) is ready, are you willing to sell whole back axle?
Zolmio
« Reply #10 on: June 15, 2010, 03:15:19 PM »
Quote
hy Zolmio,
yes but i have subpurchaser here in Germany, if it not want to have!
than we remain in contact. OK
Enzo Wink
zolmio
« Reply #11 on: June 16, 2010, 07:52:59 AM »
OK, keep in touch. Have nice rallying.
Zolmio
