August 24, 2026, 10:40:02 AM
| | |-+  no fuel being pumped
Author Topic: no fuel being pumped  (Read 30669 times)
jack1
« on: March 15, 2011, 11:29:21 PM »
hi all,,all fuel lines are clear and a brand new pump fitted and plenty of fuel in the tank,,,,is there any reason that the pin behind the pump would not work???
1996  850r (sleeper)
« Reply #1 on: March 15, 2011, 11:37:25 PM »
Is it in contact with the cam inside? Some pumps use a spacer block some don't.
jack1
« Reply #2 on: March 15, 2011, 11:48:19 PM »
dont know dave, he replaced it as it came off  ,,he put the pin in as far as it goes and with the pump off he turned over the car and the pin never moved??
1996  850r (sleeper)
« Reply #3 on: March 16, 2011, 12:42:37 AM »
 Huh What do you mean by the "pin"? The lever that makes the pump work is part of the pump so it can't  be put in without it. Does the rotor arm in the distributor turn when you crank the engine? (check by removing the distributor cap and cranking the engine)
jack1
« Reply #4 on: March 16, 2011, 01:01:20 AM »
'pin'  the pin  about 2inchs long  that hits the lever in the pump to make the pump work
1996  850r (sleeper)
jack1
« Reply #5 on: March 16, 2011, 01:05:36 AM »
hi,yes all works got spark the lot ,,as above just getting no fuel to go through the pump
1996  850r (sleeper)
« Reply #6 on: March 16, 2011, 02:42:18 AM »
But the pin is part of the fuel pump so I can't see how that was put in without the pump.  Huh
« Reply #7 on: March 16, 2011, 09:03:51 AM »
Maybe the diaphram inside has a hole in it?  this would stop it pumping.
Take it off the engine and get a piece of pipe and some fuel and check it by hand if it doesn't work will probably be dud diaphram.
jack1
« Reply #8 on: March 16, 2011, 09:02:18 PM »
[/quote
thats not what the  pump looks like,,,feed goes in from the bottom and outlet is from the top ,,pin is about 40ish ml long and slides into the block and then the pump slides on over the bolts and into place
1996  850r (sleeper)
« Reply #9 on: March 16, 2011, 11:14:37 PM »
Maybe you should describe the car and engine Ivor...?  Wink
jack1
« Reply #10 on: March 17, 2011, 02:26:57 AM »
[/quote
yes that might help,,,its  a  1980 128  1300
1996  850r (sleeper)
« Reply #11 on: March 17, 2011, 08:20:42 AM »
I see you have a 132 1800 ES on your signature now as well - Reality or an ambition...? Smiley
« Last Edit: March 17, 2011, 11:12:40 AM by kev131 » Logged
« Reply #12 on: March 17, 2011, 10:56:24 AM »
Oops, sorry! I just assumed it was a 131. Ignore everything I've said in that case. I love 128s (I want a green 1100 as a daily driver  Grin ) but I know nothing about their fuel pumps.
« Reply #13 on: March 17, 2011, 11:44:10 AM »
Try to suck some fuel to the front from the reservoir and then try throw some directly in the carb. This should make the pump going Wink
jack1
« Reply #14 on: March 17, 2011, 09:06:50 PM »
thats on there since the gold resto i had  kev,,,,like you the next fiat i buy will be a s3  132 Wink
1996  850r (sleeper)
