October 15, 2026, 01:53:44 PM
| |-+  Down to Business (Moderator: Admin)
| | |-+  NEW 7, 8 & 9 x 15 Wheels by Group 4 Wheels
Pages: 1 [2] 3 4 ... 7 Go Down Print
Author Topic: NEW 7, 8 & 9 x 15 Wheels by Group 4 Wheels  (Read 116692 times)
tonystar801
« Reply #15 on: July 09, 2011, 07:18:47 PM »
hi ,
im intersted for 4 wheels : 2 front and 2 rear , i have a 131 racing with stradale kit , what's the dimension of wheels for this?
I want 15x8 fron and 15x9 rear , but what's the ET ?
Thanks.
And what's the price shipping to france Lyon?
131grp4
« Reply #16 on: July 11, 2011, 04:54:50 PM »
hi ,
Thanks.
Hi Tonystar801,
If your car is a "road car" then you're best off running the wheels so that the wheel edge sits just inside of the wheel lip.
See what size your current wheels are and how much further out you'd like them to be, you can then see where they would finish on the inner edge, make sure your car is on full lock so to check for clearance on suspension/springs. Once we have this information along with your current wheels offset, we can work out what's required for the new wheel.
OR....I'M SURE SOMEONE HERE KNOWS THE ANSWER???
Shipping to Europe works out to about ?12 per wheel by Fedex.
Jonathan
131grp4
« Reply #17 on: July 11, 2011, 04:59:20 PM »
Hi All,
In the following 2 pictures you can see the split bottom core (face) start it's journey.
On the lathe is the 8", on the drill is the common (7, 8 & 9") outer dish section.
Jonathan
131grp4
« Reply #18 on: July 19, 2011, 01:59:03 PM »
Hi All,
Not very exciting photo's I'm afraid, they should start later this week...I hope.
(No.1 is bottom picture & work up).
1. Please find attached the photo of the finishing cut of the lower bottom core face. As you see it is where the 7 8 and 9? upper bottom sections will locate.
2. Please find attached the picture of the underside of the 8? upper section of the bottom core in the cnc.
3. Find attached photo of 7? upper bottom core having the rear location profile machined.
Jonathan
131grp4
« Reply #19 on: July 19, 2011, 02:00:25 PM »
This should be the top picture, No.3.
131grp4
« Reply #20 on: August 14, 2011, 06:50:32 PM »
After a 2 week factory holiday shutdown, work has resumed in earnest. This shows the upper section ofthe 8" PAG-1580 Bottom core from the underside and about to be bored out to the sprue dimensions.
131grp4
« Reply #21 on: August 14, 2011, 06:51:49 PM »
‎7 & 8" waiting to be machined.
131grp4
« Reply #22 on: August 14, 2011, 07:56:37 PM »
Lower bottom core section completed/ fully turned andwaiting to have all the fixing and location details machined into it.
131grp4
« Reply #23 on: August 14, 2011, 07:57:36 PM »
Attached are the pictures of the turned completed underside of the 8 & 9"upper bottom cores with sprue details in place.
131grp4
« Reply #24 on: August 14, 2011, 07:59:09 PM »
The 7" having the same details machined into it.
131grp4
« Reply #25 on: August 14, 2011, 08:00:04 PM »
Die side castings, yet to be machined.
131grp4
« Reply #26 on: August 14, 2011, 08:00:57 PM »
Top core castings waiting to be machined.
131grp4
« Reply #27 on: August 14, 2011, 08:02:51 PM »
‎8? upper bottom core assembled into shared lower bottom core piece ready to be milled on Monday.
131grp4
« Reply #28 on: September 06, 2011, 06:27:30 PM »
Hi All,
Haven't posted on here for a while and have missed an update...but now armed with a swish new Mac I can bring everyone up to date.
PAG 1580 bottom core
131grp4
« Reply #29 on: September 06, 2011, 06:29:23 PM »
Die side blocks
Pages: 1 [2] 3 4 ... 7 Go Up Print
