October 25, 2026, 12:02:51 AM
| | |-+  Fiat 131 1600TC carburetor
Author Topic: Fiat 131 1600TC carburetor  (Read 27978 times)
PZ131
« on: April 29, 2012, 09:56:11 PM »
Dear fans of Fiat 131,
Can anyone tell me what should I do with a carburetor that wasnt working for abt 10 years on Fiat 131 1600TC? It looks very oily and dirty. Any advice?
Thank you
« Reply #1 on: April 29, 2012, 10:04:54 PM »
You can buy repair kits quite cheaply. Clean the outside, strip down, clean all parts and then reassemble with the new seals, gaskets etc.
You can buy carburettor cleaner, I usually just use standard cellulose thinners.
PZ131
« Reply #2 on: April 29, 2012, 10:11:29 PM »
thank you so much
PZ131
« Reply #3 on: April 29, 2012, 10:16:26 PM »
can u tell me what is the most usual problems with those carburetors?
« Reply #4 on: April 29, 2012, 10:48:14 PM »
No major problems as far as I'm aware if it is the standard Weber carb. The autochoke can cause a few problems but I would just try it as I'm a firm believer in the saying 'if it ain't broke, don't fix it' Smiley
PZ131
« Reply #5 on: April 30, 2012, 09:56:22 PM »
Hi mirafioriman,
thanks for the advises. now its working excellent Smiley))
cheers
N. Dinis
« Reply #6 on: June 06, 2012, 09:21:29 AM »
I'm also having trouble with my 2000 TC carburator... It's a Solex TEIE 5-9-10 and I bought a repair kit. Replaced all the gaskets and now, +/- 1 month later the main membrane is also spraying the fuel out.... I opened it and the membrane (PIAMAX) is in worst shape than the previous one... Sad Any idea why this is happening? Thanks in advance
« Reply #7 on: June 06, 2012, 09:25:34 AM »
What do you mean by "main membrane"?
Have you used any fuel additives that might have damaged it?
N. Dinis
« Reply #8 on: June 06, 2012, 09:37:00 AM »
No... only 98 oct fuel... I'll take a pic of it
N. Dinis
« Reply #9 on: June 06, 2012, 10:34:11 AM »
here are the pics...
« Reply #10 on: June 06, 2012, 10:43:28 AM »
Accelerator pump diaphragm. As long as it's not split then it should be fine.
In the bottom photo it looks as if you have some rust or paint pealing on the carburettor body. Maybe it's because of this that you don't get a good seal and it leaks?
N. Dinis
« Reply #11 on: June 06, 2012, 10:51:52 AM »
It is split... both of them. The orange one was instaled a about a month ago
« Reply #12 on: June 06, 2012, 10:55:52 AM »
If it was 'new old stock' then it's likely that it was dried out due to age and hence it split easily. If you had any warranty with it take it back and try to get it replaced. Also make sure the spring is the original and hasn't been changed by one that is too 'strong'.
N. Dinis
« Reply #13 on: June 07, 2012, 10:30:17 AM »
The spring is thin so I believe it's original... I bought it on ebay... Sad And yes it was old stock
« Reply #14 on: June 07, 2012, 12:17:44 PM »
I've had trouble in the past with 'new old stock' stuff.   Angry  The emphasis is on old rather than new  Undecided  Buy another one and hope for better luck.
