October 24, 2026, 10:10:10 PM
| | |-+  Fiat 131 1600TC carburetor
Author Topic: Fiat 131 1600TC carburetor  (Read 27966 times)
« Reply #15 on: June 07, 2012, 12:38:06 PM »
Try a company like Eurocarb as they may have new stock available.
N. Dinis
« Reply #16 on: June 07, 2012, 01:25:57 PM »
It's not easy to find for this particular model.... I also have the one I believe to be original, a webber 32, but the automatic choke is broken and I haven't found a solution for it...
farranwilliam
I am retired, enoying the classic car Fraternity
« Reply #17 on: September 13, 2012, 11:46:47 AM »
I saw your post today and I suggest you read my post made today also      BOIL THE CARB
At present I have Mirafiori Mk2 Automatic, Ritmo S85 Cabrio, Ritmo 105 TC, Fiat X1/9 1.5,  Kadett D 1.2,
hammerbeirne
« Reply #18 on: September 18, 2012, 07:01:40 PM »
Just a quick Question when i accelerate hard the car dies like its not getting enough fuel would this be caused by a torn diaphragm?
« Reply #19 on: September 18, 2012, 09:40:23 PM »
The diaphragm is for the accelerator pump, if it's not working you don't get accelerator enrichment when you hit the pedal. If you ease into the throttle the car will accelerate all the way to the redline. You don't have a fuel supply issue, you have a delivery issue. The diaphragm is a common part and a not uncommon point of failure, it shouldn't be too hard to find a new one.
I just re-read the whole thread. It's a solex, drop it in a rubbish bin and fit a weber.
N. Dinis
« Reply #20 on: November 25, 2012, 11:02:32 AM »
I know it's been awhile since I last posted in here but my taxi also failed and I 've stopped my life till now. So, I followed Taz suggestion and putted the solex apart. I had original 1600 ohc webber and I placed it on the engine. I believe it's a 32 and yet I'm still having problems with the carburator. I believe that fuel delivery is not enough.... I'm getting tired of this problem. So, What carbs can be used on these engines (2000TC from Racing) wich cars use them?
« Reply #21 on: November 26, 2012, 09:36:16 PM »
2000cc engines were fitted with a 34 ADF. 32 ADF was fitted to the 1600cc engines.
N. Dinis
« Reply #22 on: November 27, 2012, 09:41:22 PM »
Arround here carbs are not easy to find. I'm trying to apply a Delta GT inlet and respective carburator, let's see how it goes...
