October 24, 2026, 12:31:12 AM
| | |-+  Diff oil seal
Author Topic: Diff oil seal  (Read 8295 times)
« on: May 22, 2012, 04:58:27 PM »
Anyone know where a dif oil seal can be found - Belongs right at the front of the diff where it meets the propshaft. Have a slight leak on the 1600 Super.
While on the subject of seals/gaskets, has anyone tried these kits and this seller?
Looks good value...wonder about the quality at this price.
http://www.ebay.co.uk/itm/370614488466?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
« Reply #1 on: May 22, 2012, 05:39:37 PM »
If you get the size (should be on the old seal or someone here will give it to you) get a nitrile seal from http://simplybearings.co.uk.
« Reply #2 on: May 23, 2012, 09:50:32 AM »
Good find Theo.
Kev, i think this is what you need- size- 36x68x10
http://simplybearings.co.uk/shop/advanced_search_result.php?search_in_description=0&sort=2a&search_3fields=1&keywords1=36&keywords2=68&keywords3=10&x=21&y=15
I am half way through a diff strip so can get you the numbers by tomm to be sure.
« Reply #3 on: May 23, 2012, 10:20:14 AM »
Just checked diff and original seal is,
Bore 35.8
Diameter 68
width 10
Would of thought the seal listed will do the job.
« Reply #4 on: May 23, 2012, 09:27:25 PM »
This forum is a must for non mechanically trained owners.
Thanks for the multiple offers of help either by text or PMs as well as directly on the forum. I now have 2 on order from Germany and I'll check the measurements against what you've said Bobby.  Smiley
