August 27, 2026, 02:40:00 PM
| | |-+  Fiat 131 Racing Window Regulator
Author Topic: Fiat 131 Racing Window Regulator  (Read 6474 times)
cypriot
« on: June 05, 2012, 02:10:57 PM »
Hi all,
I am new in this forum. I am not sure if I am at the right section but I should ask this.
I have 1981 Fiat 131 2.0 TC Racing (Gr. 4 Abarth Tarmac rally car replica) which I try to complete restoration.
I try to find window regulator / winders for this vehicle. According to the web search 2 door 131 window regulator / winder diffrent than 4 door (front doors) window regulator / winder.
by the way both parts looks same,
what is the difference? length of wire ?
cheers
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
H?rmann Intake Manifold
Weber 40 IDF Carbs
GC Spec FW
« Reply #1 on: June 05, 2012, 03:02:27 PM »
I always thought the windows regulators were different between 2 and 4 door cars. Must be the length of the wire as I can't see why else they'll be different. I have managed (twice) to change the cable in the regulator of my Silver Sport. I used picture hanging wire from a local frame shop and it proved strong enough. So if your problem is a broken wire then you may be able to change it.
cypriot
« Reply #2 on: June 05, 2012, 05:18:11 PM »
Hello,
as I know and according to my repairman, 2 door & 4 door window regulators looks some and his only idea is the wire length should be a different.
by the way I have only one window regulator (its wire faulty) and the other one missing.
In North Cyprus it is easy to find body parts if it is not 2 door specific.
cheers
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
cypriot
« Reply #3 on: June 09, 2012, 09:54:12 AM »
Hi all,
I just came back from spare parts shop and
131 4 door front window regulators are same with the 2 door window regulators.
Only difference is a 2 door window regulator has 10 - 15cm longer wire  Grin
and it is possible to replace wire with longer one
I hope this information help other 131 enthusiast
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
