August 25, 2026, 12:30:21 PM
| | |-+  What are the extra components on the top of this engine...?
Pages: 1 [2] 3 Go Down Print
Author Topic: What are the extra components on the top of this engine...?  (Read 38963 times)
« Reply #15 on: June 12, 2012, 01:24:54 PM »
In fact, looking at the first photo again, this engine is fitted with a vacuum advance distributor but the vacuum advance pipe is not connected! So I'd say this engine is not running well and must be down in power. Plus is it normal for S3 131s to have a distributor fitted to the head? Should it not be in the block? And where's the windscreen washer bottle?
« Reply #16 on: June 12, 2012, 01:28:01 PM »
Could it be that components were used from the American Pininfarina 124 Spider?
« Reply #17 on: June 12, 2012, 01:34:46 PM »
It's not my car Mike - But I'm looking at it.
Theo - Any views on whether there could be long term damage to the engine from the installation as it looks...? I did drive it and it didn't seem particularly quick....but not too sluggish either.
On the later S3s the washer bottle and radiator expansion tank are a single square edged unit with separate reservoirs - Mounted behind the grill.
« Last Edit: June 12, 2012, 01:41:11 PM by kev131 » Logged
« Reply #18 on: June 12, 2012, 01:56:34 PM »
No I don't think there'll be any damage at all. That's how the low emission engines came from Fiat anyway. But don't expect it to get quicker by simply taking off the 'extra' pipework. It will take a complete engine rebuild to Euro-spec to gain back the 'missing' power and unfortunately that kind of engine rebuild doesn't come cheap! On the other hand, this might be a Euro-spec engine and just by connecting the vacuum advance pipe you'll get back all the missing horsepower! That'll be a nice cheap fix!  Grin
Of course they are, I remember now and I can see it in the photo  Undecided
« Reply #19 on: June 12, 2012, 02:01:02 PM »
I love things like this!  Grin
Kev, the washer bottle was only integrated into the expansion bottle on certain of the series 3 TCs as both my Dec 82 (XPE613Y) and my brother's Jan 82 (PBL712X) 2000 series 3 Supers had separate bottles like the earlier cars. It was probably a later mod. Huh
Theo, some series 3 TC engines had the dizzy mounted on the exhaust cam as there was no room in the usual block position as access was limited due to either a Supercharger (as the Volumetrico) or air conditioning pump. Also, some markets (particularly the USA but also some other markets) had an air injection pump mounted on the inlet side of the engine which also meant that access to a block dizzy was almost impossible.
I doubt that there would be any long term damage to the engine as the kits looks like a factory fitment. My 1976 124 CS1 Spider had it's emission kit removed without any ill effects - had the "two sets of points" dizzy fitted, which ran like clockwork once I fitted electronic ignition Grin Cheesy. The engine pictured already has electronic ignition as it's a 2000 so no such issues. Cool
I assume this engine runs on unleaded, which would probably mean it's a 'low compression' unit in any case.
« Reply #20 on: June 12, 2012, 02:15:20 PM »
Yes I knew that  Wink and I've had a good look at both Graham's and Albert's Volumetricos both of which have a head mounted dizzy. But this car is not a Volumetrico so the head mounted dizzy makes it seem like a USA spec engine. I know the USA 1800 twincams in the 131s had a head mounted dizzy  Undecided
« Reply #21 on: June 12, 2012, 02:24:50 PM »
The USA did not get the Series 3 131, but they did get the Series 2 Supermirafiori/Super Brava with the 132 2000 unit  Grin This is a 1984 Series 3 131 2000 TC ergo is cannot be from the USA. Shocked Grin
And it's LHD so it cannot be Australian either. Huh
The plot thickens......... Cool
« Reply #22 on: June 12, 2012, 02:59:44 PM »
But I thought we are considering the possibility that this car didn't come with this engine originally.  I think we need to know where the car is and where it came from to make some more educated guesses.
« Reply #23 on: June 12, 2012, 06:31:50 PM »
I don't think it's the wrong engine but it's definitely the wrong air filter box for a 1984 131 Super. It should be fitted with the later air box (which automatically thermostatically regulates whether to draw in fresh air or pre-heated air) with the long cold air intake that reaches forward and has the longer paper consatina warm air 'hose' which runs around the front of the engine between the radiator and water pump, and connects to the 'flange' that faces forward above the exhaust manifold. The air box currently fitted is of the earlier type which should have the shorter paper air hose running across the top of the cams into a different housing above the exhaust manifold - hence the wrong looking kinked paper 'hose' on this car as it is correct for the engine and not the air box.
Still don't think it's a US spec 124 Spider lump - but not so sure now Huh. If you were changing the engine surely you'd remove the emission kit. Huh
131 Lover
Fiat power No mercy !!!
« Reply #24 on: June 12, 2012, 08:02:16 PM »
Hi!
 since we did not get any -84 to Sweden i dont know about this car that you show specific, but the vacum advance can be an aftermarket distrubutor, i havent seen any here with vacumadvance!
The power output is the same,110bhp on the paper, at least here even with the emission on,its when its to old it starts to suck air from all airhoses and EGR valve its getting astmatic!
These emissions is just to block in the head and throw the rest away,i cant see the exhaust manifold,it can take exhaust from there instead of inside the head,just take an older exhaustmanifold and then it works fine!
I can try to get a pic of a 131 2000tc from -83 so you can se how it was delivered new here!
Here you can see the 2 part bottle next to the radiator and the distrubutor on the head!
If someone is intressted in a drawing of the emission system ,i can take a pic of it and bring it here?
« Last Edit: June 12, 2012, 08:12:55 PM by 131 Lover » Logged
These are my Fiats
2x 131 2-door 1600cl -81
« Reply #25 on: June 12, 2012, 10:19:37 PM »
All 2 litre 131s in OZ had cam mounted electronic ignition. We got a sort of series 2.5, with some series 2 stuff and some series 3, some had the washer bottle and coolant bottle beside the radiator, although later versions had 2 separate bottles and a wider twin fan radiator. Some OZ motors had "Aust" stamped in red on the side of the inlet cam box.
wak131
OOo ///// oOO
« Reply #26 on: June 13, 2012, 01:03:13 PM »
I had removed the same exhaust gas recirculation system from a VX Argenta.
It was from Switzerland i hope.
« Reply #27 on: June 13, 2012, 01:24:47 PM »
Thanks for that - Any difficulties in removing the components and more importantly, was it worth the effort in improved performance, reliability, emmissions, etc  Smiley
wak131
OOo ///// oOO
« Reply #28 on: June 19, 2012, 10:30:52 PM »
Well the thing is, i just removed it from the engine to see what it really is. The car was not runing for long time and i didn?t run it after either. The VX part was missing. I "saved" it from a garden where it had stayed some years, left without interest.
So cannot really answer your question. But from a mechanic point of view i agree with blinding it with bolts or rather welding the holes in the manifold and it should run just better without added exhausted gases in the inlet instead of fresh air.
wak131
OOo ///// oOO
« Reply #29 on: June 24, 2012, 08:07:31 PM »
here is the pic
Pages: 1 [2] 3 Go Up Print
