August 25, 2026, 02:13:06 PM
| | |-+  valve clearance
Author Topic: valve clearance  (Read 26147 times)
« Reply #15 on: November 09, 2012, 09:10:20 PM »
Nice looking car Wink
Love the colour too Grin
keith m 131
« Reply #16 on: November 10, 2012, 10:10:34 AM »
Thanks Mirafioriman,
The colour is Fiat 124 Rosso Damask,
Keith
124AC
« Reply #17 on: November 20, 2012, 11:33:19 PM »
Did you check the carb as suggested by David earlier?
The Weber is a 2 stage unit with the second barrel providing the extra surge to accelerate and get the top end when you open the throttle.
Take the filter off and look down the carb.  The main barrel should be closest to the cam box.
If you open the throttle linkage the main barrel flap should open and squirt petrol into the manifold.  At about 3/4 throttle the linkage should engage the secondary barrel and both should then be open at full throttle.
Please check, as I checked a Monte Carlo carb last week that had siezed after being stood for a short time!
keith m 131
« Reply #18 on: November 21, 2012, 11:34:40 AM »
Hi Duncan,
I have checked and both barrels are wide open (vertical ) at full throttle and the throttle set up works smoothly.
Keith
« Reply #19 on: March 23, 2013, 09:34:05 PM »
Well did you get to the bottom of the problem ...
keith m 131
« Reply #20 on: March 27, 2013, 07:29:21 PM »
Hi Jason,
Ill health and work has prevented me from doing any further work to the car, but over easter I am planning on returning to the garage and will of course report back,
keith
