October 24, 2026, 05:59:40 PM
| | |-+  Wheel Spacer Fiat 131 Abarth Replica
Author Topic: Wheel Spacer Fiat 131 Abarth Replica  (Read 15330 times)
rosi
131 Rally
« on: November 16, 2012, 01:09:11 PM »
Hello all,
Question; I would like mounting a set of wheel spacers for my Fiat 131 Abarth Stradale replica.
My wheels have ET 15
-Do you have a recommendation of types of wheel spacers?
-Which broadness is ideal
Many thanks for pictures and links to buy the spacers.
Rosi
« Reply #1 on: November 16, 2012, 02:59:31 PM »
it's a question of wide 7, 8, or 9" inch    Huh
sdebez
fiat 131 gr 4.5
« Reply #2 on: November 16, 2012, 10:43:42 PM »
the thickest you can get, but so the tyres dont rub the body.
« Reply #3 on: November 16, 2012, 10:56:49 PM »
It's one of those things you have to figure out by yourself. Just take some measures. It all depends on the rear axle and your rims.
adcostas
« Reply #4 on: November 17, 2012, 03:18:30 AM »
Hi on my replica for the rear  i could not find anything off the shelf so i had them done 10 cm for the front i got them from ebay also i got wheels with a bit of offset
cheers
Fiat 2L 131 abarth rep
rosi
131 Rally
« Reply #5 on: November 17, 2012, 01:25:52 PM »
My 131 Replica has Gotti wheels 8x15 / ET 15 / 205/50 15 rear and 6x15 / ET 15 / 195/50 15 front.
What do you mean 20mm spacers front and rear (Axle 40mm)
rosi
131 Rally
« Reply #6 on: November 17, 2012, 01:36:09 PM »
here is a picture
« Reply #7 on: November 19, 2012, 02:09:05 AM »
If i  remember correctly mine are 45 mm ...
« Reply #8 on: November 19, 2012, 09:30:37 AM »
normally Fiat 131 Abarth stradale have 7x15 ET 0
you use 8x15 / ET 15 rear and 6x15 / ET 15 front
it's possible 20 mm in front are to less and 20 mm rear to much!
i think it's better to take self the measurement and than decide
which spacer!
BTW: Miro nice brakes  Shocked
rosi
131 Rally
« Reply #9 on: November 19, 2012, 06:13:57 PM »
Many thanks for your answers.
what do you mean of this spacers:
http://www.ebay.de/itm/SPURVERBREITERUNG-40-mm-FIAT-Stilo-4x98-NEU-/270505028673?pt=DE_Autoteile&clk_rvr_id=412809967790
How much are the diameter of the central hub? 58.1mm?
regards from switzerland
rosi
« Reply #10 on: November 19, 2012, 07:19:48 PM »
yes it's 58.1mm!
