August 29, 2026, 04:13:53 AM
| | |-+  44IDF Airbox photos
Author Topic: 44IDF Airbox photos  (Read 13939 times)
Yagmur
« on: December 29, 2012, 04:15:05 PM »
Hello My friends,
We are working on a 131 Racing rally project ; would like to see some Weber 44 IDF airbox photos...
« Reply #1 on: December 29, 2012, 09:34:30 PM »
I can send you IDF 40 and weber filters pictures but if its 44s i can't help.
Only problem with IDF carbs is you need to make your own cables and linkages up as I tried hard to find some but failed, you can easy find cables and linkage for side draught webber though.
If you can find linkages and cables for IDF's let me know  Wink
« Reply #2 on: December 29, 2012, 10:13:25 PM »
For IDF carburators you can just use the same linking as the ones used on TC engines. It's only that the gas cable lies a straight fit to the right carburator. But that's not a problem. At least it wasn't for me and and i drive this set-up since 1988.
« Reply #3 on: December 30, 2012, 10:49:46 AM »
Here's a picture of air boxes on top of my 40 IDFs; they fit 44 IDFs too.
Accelerator cable comes from Ritmo 130TC, hence the length. Setup works very smooth  Smiley
FIZMO
« Reply #4 on: December 30, 2012, 01:25:17 PM »
this is what ill be run but they are 48's should b cool fo your 44
http://www.ebay.co.uk/sch/i.html?_nkw=itg+idf+webers&_sacat=0&_odkw=itg+webers&_osacat=0&_from=R40
« Reply #5 on: December 31, 2012, 02:36:58 PM »
Hi Yagmur,
http://www.google.de/imgres?q=carbon+airbox&hl=de&safe=off&sa=X&tbo=d&biw=1440&bih=785&tbm=isch&tbnid=x9fcDeqULz7fcM:&imgrefurl=http://www.borlainduction.com/airbox.htm&docid=9yQsh4l5ODdr7M&imgurl=http://www.borlainduction.com/Filter/Filter.imgs/airbox_carbon_back.jpg&w=216&h=144&ei=P6DhULWdEcjZ4QS5yICoAw&zoom=1&iact=hc&vpx=1049&vpy=323&dur=3299&hovh=115&hovw=172&tx=100&ty=75&sig=116156484509894595464&page=1&tbnh=115&tbnw=172&start=0&ndsp=28&ved=1t:429,r:12,s:0,i:124
if you have someone how can work with glass fibre or Carbon you can build this by yourself! Look Picture:
i think that is what you are searching.
Enzo
« Reply #6 on: December 31, 2012, 11:54:22 PM »
In the shed I've got a 124BC set of IDFs on the original manifold, with air cleaner and linkages etc. I can take some photos if you want to see how it all fits together.
Yagmur
« Reply #7 on: January 01, 2013, 12:06:53 AM »
[/quote
Hi,
Yes I would like to see...]
« Reply #8 on: January 01, 2013, 03:38:53 AM »
I don't know how the cable attaches for a LHD, but for RHD a bracket bolts on to the rear of the cambox. The linkage pivots on 2 brackets (not shown) that bolt to the side of the manifold.
« Reply #9 on: January 01, 2013, 03:43:16 AM »
The original filter housing had 2 air horns at the front, but in this case some previous moronic owner has hacked them off. This is what the yanks refer to as a "Turtleback" air cleaner.
« Reply #10 on: January 01, 2013, 03:48:51 AM »
The original filter elements have been unobtainable for years, but an OZ company now makes a reusable foam filter to fit the original air cleaner. Bonnet clearance in my 131 was not an issue.
FIZMO
« Reply #11 on: January 01, 2013, 05:46:32 AM »
@ enzo looks good i love the look and design...
thanks for the like i might have to have a play around!!
