July 29, 2026, 10:15:19 AM
| | |-+  bigger breaks?
Author Topic: bigger breaks?  (Read 19193 times)
lorf
« on: August 02, 2013, 05:08:37 PM »
Hallo, I'm just wondering if anyone has mounted bigger breaks on the 131. Currently mine is fitted with uno turbo breakes because this is the only one I know of that can be fitted without any modification. So to my question.. does anyone know of any other breaks that can be fitted without any large modification . Feks from : fiat coupe, lancia delta, punto abarth , and so on......
« Reply #1 on: August 02, 2013, 05:19:16 PM »
My 131 is fitted with Fiat Bravo disks and callipers at the front.
« Reply #2 on: August 02, 2013, 07:49:07 PM »
Theo, are yours vented or solid?
lorf
« Reply #3 on: August 02, 2013, 09:08:48 PM »
Thanks for the information it's god to know there is more options getting better breaks.
Just to inform so is the uno turbo disks vented.
lorf
« Reply #4 on: August 02, 2013, 09:16:58 PM »
What year and engine type on the bravo this brakes come from?
« Reply #5 on: August 03, 2013, 11:50:13 PM »
Solid
Not exactly sure. They are from the original Bravo (before the Stilo) and they are the solid disks not the vented HGT discs. I think all other Bravos had the same disks?
« Reply #6 on: August 03, 2013, 11:56:59 PM »
If you do a forum search you'll find a few peoples thoughts on bigger brakes. I've got Regata 100s calipers and discs on the front of mine and a 132 disc rearend.
selem
« Reply #7 on: August 04, 2013, 03:00:51 PM »
me also front regata 100s rear 132 disc.
fiat 131S
« Reply #8 on: August 05, 2013, 09:30:02 AM »
The rear brakes on my car are 131 front disks with VW golf callipers. The disks are a straight fit onto the axle but the callipers needed custom modified mounting brackets and the panhard rod vertical mount bracket had to be slimmed slightly for the calliper to fit. But I think that Fiat Croma rear callipers could possibly be fitted with less modifications needed.
« Reply #9 on: September 14, 2013, 08:50:30 AM »
 A well set up standard brake set up always never let me down in the past for home fast road use , not track days or  the racetrack . as i never realy had a long enough race with anybody or my self  Grin
  Only once 25 years ago i had mintex fast road pads thats all and a mental ride home down twisty country roads and at that time the discs where worn down to about 7mm and where glowing in the dark but never faded and allways stopped on the button ,but i did change them soon after  Grin Grin Grin there ability usually out performs yours  Cheesy
From toad
http://www.131mirafiori.com/smf/index.php?topic=6384.0
« Last Edit: September 14, 2013, 10:39:17 AM by jasonh131 » Logged
« Reply #10 on: September 16, 2013, 10:57:27 PM »
Theo did you had any modifications made for the front brakes or it was a straight fit?
« Reply #11 on: September 17, 2013, 08:55:27 AM »
It's a straight fit using the original Bravo brackets for the calipers but they're too large to fit behind 13" wheels so you must have at least 14" wheels.
aea180
« Reply #12 on: November 10, 2013, 01:09:06 AM »
Hello!
I have fiat ritmo 130tc vented front disc and calipers.
Is very easy to fit.
« Reply #13 on: November 10, 2013, 07:55:24 AM »
I have Uno Turbo discs and callipers fitted to my 1600 CL, like Lorf has. The discs have the same diameter as Original. Callipers are an easy fix without having to do any modifications.
« Last Edit: November 10, 2013, 08:20:22 AM by mirafiori76 » Logged
« Reply #14 on: November 11, 2013, 09:31:31 AM »
This will fit plug and play!
it's from Fiat Palio 1,6l-16V
disc are from Brembo (slotted) on the pic,
but you can use original ventilated , or cross-drilled,
Enzo  Smiley
