October 23, 2026, 09:33:18 AM
| | |-+  FS: G.4 x-member/x-brace kit
Author Topic: FS: G.4 x-member/x-brace kit  (Read 5983 times)
131rally
« on: January 11, 2014, 07:39:07 AM »
I have original ex-works x-brace, the one you bolt your engine and the TCA. I drew the special pieces to CAD and had them cut. I just welded one to my friends car. The pieces are tricky to make with handtools, atleast if you want them to be finished nice. Complete kit with 7 pieces 45? (+VAT 24% to EU buyers).  I can also make it completelly ready, 190? including brace+kit+welding+mediablasting (+VAT). Worldwide delivery. There works piece has lots of reinforcing seam welds. I can give drawings where you need to weld to make it right. The bottom plate and curved pieces are 2mm mild steel, the other four are 4mm and bit tougher steel.
The bottom piece is spot welded originally, so I had it cut for you to weld through the holes, looks like spot welding. If somebody has spotwelder, I can order them without holes too, just let me know, same price. In the pictures I welded it with MIG/MAG instead of original TIG welding cause I ran out of Argon and I needed to have it done.
marko1vaisanen(atatat)gmail.com or PM
131rally
« Reply #1 on: January 11, 2014, 11:13:39 AM »
http://131abarth.com/?page_id=75 you can see how it looks when welded completely ready.
131rally
« Reply #2 on: September 08, 2014, 08:25:10 PM »
Couple of reinforcing kits still available.
