September 21, 2026, 11:47:01 PM
| | |-+  Weber 40 idf 13 / 15
Author Topic: Weber 40 idf 13 / 15  (Read 19147 times)
cypriot
« on: January 12, 2014, 01:51:43 PM »
Hi all,
My restoration project still going very slowly and I try to collect missing parts.
I just ordered weber 40 idf rebuild kit and prepare a list for the main jets, air corrction jets, idle jets and pump jets.
I also need to replace faulty screw / jet but I dont know what is it name. I post picture which show unscrewed one Can you please help me to find out its name. I mentioned the screw which is yellowish color and just seen at the right of the inlet manifolds "2000" stamp / mark
« Last Edit: January 26, 2014, 11:13:59 AM by cypriot » Logged
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
H?rmann Intake Manifold
Weber 40 IDF Carbs
GC Spec FW
« Reply #1 on: January 12, 2014, 02:09:25 PM »
http://www.di-michele.de/html/weber_einzelteile_bilder.html    Wink
cypriot
« Reply #2 on: January 12, 2014, 02:18:55 PM »
Thanx but couldnt find it in that website. As I understand it is a weber 40 idf 13 / 15 specific. Each carb have two of them and one of the carbs I have one faulty which stick inside and someone damaged it before I bought carbs. It doesnt have anything to put screw driver and unscrew it  Sad
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
« Reply #3 on: January 12, 2014, 04:27:57 PM »
Emultion tube ..
 dcoe one s
 and aditional jet slots in the top
http://www.ebay.co.uk/itm/like/360560786848?hlpht=true&ops=true&viphx=1&limghlpsr=true&lpid=101&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=101&ff19=0
« Reply #4 on: January 13, 2014, 06:09:14 AM »
It's not the emulsion tube. Don't know the name of it, but after recently rebuilding and fitting IDFs to my 131, it is definitely a separate item to the emulsion tubes. I had a good exploded view of the 13/15 carbs but deleted it and can't find the site I got it from.
« Reply #5 on: January 13, 2014, 08:20:42 AM »
here is an explode drawing here you can see all the spare parts for an 40 IDF
http://www.di-michele.de/html/40_idf_zeichnung.html
cypriot
« Reply #6 on: January 13, 2014, 06:51:58 PM »
Hello,
Thanks for your replies. This schematic is belongs to the weber 40 idf 70 or XE type they are later type and different than early weber 40 idf 13/15 which are fitted by fiat factory to the Fiat 124 Sport models and was an option Fiat 131 's  also some independent tuning firms like Hormann also fitted these.
Anyway I found out name of the part. It is called "Starter jet" this morning my repairman manage to remove faulty / sticky starter jet without damage the carb.
I am waiting rebuild kits and correct jets in order clean and assemble carbs.
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
cypriot
« Reply #7 on: January 25, 2014, 05:49:25 PM »
Goodevening,
I received rebuild kits and carefully clean and rebuild these carburattors. Most probably next Saturday they will be fitted to the vehicle.
I might share video of them while vehicle working who knows  Wink
I suppose you all drive Fiat 131 at least some part of your life but I havent drive any yet. I am really in a hurry to finish my project hear sound of webers and drive it.
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
cypriot
« Reply #8 on: January 26, 2014, 11:22:23 AM »
Hello,
Here is the carb jetting ;
34mm choke tubes (32mm standard chokes bored out)
145 main jets
180 air correction jets
45 pump jets
55 idle jets
F11 emulsion tubes
I know that it is not best / dyno proven jetting butI thought  and hope it will work with my vehicle 's engine which is mildly modified
Engine specs 85mm high compression pistons, 124 abarth cylinder head mildly ported, cr is between approximately 10.5 / 1 (in anycase not less then 10.3 / 1 and not more than 10.9 / 1 )
4-1 exhaust manifold, gc specs flywheel.
I also planning to put performance camshafts
Cherrs
« Last Edit: January 27, 2014, 04:53:31 AM by cypriot » Logged
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
« Reply #9 on: January 26, 2014, 09:17:59 PM »
Merhaba Ali,
here is the setting for my carbs (IDF 40 13/15):
125 main jets
210 air correction jets
50mm pump jets
55mm idle jets
F11 emulsion tubes
this setting is dyno proven (see diagram at http://www.131mirafiori.com/smf/index.php?topic=1572.0)
cypriot
« Reply #10 on: January 27, 2014, 04:52:26 AM »
Merhaba Ali,
125 main jets
50mm pump jets
55mm idle jets
F11 emulsion tubes
Hello,
These are the standard setup of weber 40 idf 13 / 15 fitted to the 124 sport models and their engines were 1.6 liter.
I got information from gc forum  Grin
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
