October 25, 2026, 12:09:37 AM
| | |-+  Turn the key and dead!
Author Topic: Turn the key and dead!  (Read 12511 times)
Crazypierre
« on: February 01, 2014, 07:16:59 PM »
Hi everyone
Been using my yellow 1979 1300 CL without any problems for many years now but today, I drove to the shops, parked up, came back, turned the key and nothing.....
Not a click, not a slight turning over, just dead. The battery is new and checked it with a voltmeter and it's fine but at the electrodes and on the battery cable ends.
Got four burly lads out of the pub to give me a push start and it started no problems.
I think I know what the problem but would like to validate my diagnosis with you fellas.
Cheers in advance.
Pete
« Reply #1 on: February 01, 2014, 09:26:37 PM »
Sounds like the ignition block Smiley
« Reply #2 on: February 01, 2014, 09:35:24 PM »
Starter motor! I had similar symptoms recently, ended up being starter motor brushes were worn. Check you have 12 volts on the wire to the starter solenoid when ignition key turned to start, if yes it's a starter issue, if not, electrical issue elsewhere.
« Reply #3 on: February 01, 2014, 09:35:50 PM »
Contacts behind ignition barrel, mine happen in supermarket carpark 2 years ago had to hot wire it!
Crazypierre
« Reply #4 on: February 02, 2014, 07:47:13 AM »
Thanks.
I had not considered the ignition barrel.......
Mick
I will start with checking the starter motor. Is it under the carb?  But how do I get to the wires to put a voltmeter onto it.  I would have thought I'd have to put the car on ramps and get to it from underneath but I can't start it....
Jasonh
If it's the contacts behind the barrel, how do I get to those?
Thanks all, my car is stranded in my drive.......
Peter
« Reply #5 on: February 02, 2014, 09:24:34 AM »
Try a cable streight from the starter main terminal to + battery teminal  .are there any dash lights? Ignition barrell behind coloum shroud
Crazypierre
« Reply #6 on: February 02, 2014, 10:16:26 AM »
Hi. Yes dashboard lights on. I tried knocking the starter to engage the brushes but no luck.
Peter
« Reply #7 on: February 02, 2014, 03:16:15 PM »
On a lighter side, read this: http://www.131mirafiori.com/smf/index.php?topic=5549.0
No great help, but fun reading.
But seriously: it might be your starter that's broken.
« Reply #8 on: February 02, 2014, 08:58:38 PM »
Mick
Peter
Assuming you're running a twincam, it's under the inlet manifold, a torch and a mirror will give you a better idea of what you're up against. There is a wire that goes on to a spade terminal on the starter solenoid on top of the starter motor. If you pull the wire off, measure voltage between wire and ground while someone turns the key, you should get close to battery volts. If good your starter is suspect, if volts are low, ignition switch would be my next point to check.
Crazypierre
« Reply #9 on: February 08, 2014, 08:16:28 AM »
Thanks All.
Put a small hammer under there, gave the starter and solenoid a bit of a knocking with the small hammer and the car started........
could it be the brushes?
But when if didnt start there was no clicking sound.....which would indicate solenoid or ignition barrell
« Reply #10 on: February 08, 2014, 08:53:53 AM »
Just change the starter ,it is 30 years old  Cheesy
