October 24, 2026, 05:01:33 PM
| | |-+  Advice !
Pages: 1 2 [3] Go Down Print
Author Topic: Advice !  (Read 40363 times)
POQ 131
« Reply #30 on: May 08, 2014, 09:32:22 PM »
Thanks for the reply finnie.
The set up shown on the E Bay link is actually different to the one you have & the cable pull comes in from the back of the rear carb & not across the engine & cam box like yours. Had you got this one in the link then your cable problem ( with the angle it goes down over the cam box) would be solved.
I think I am a gonna get me one of those.
O.
O.
finnie
« Reply #31 on: May 09, 2014, 07:51:07 PM »
This is the new cable system not the best quality and think  ill reverse it so it pulls from the front
« Last Edit: May 10, 2014, 10:44:14 PM by finnie » Logged
finnie
« Reply #32 on: May 11, 2014, 04:49:22 PM »
It's now reversed
But anybody ever fitted twin cable and how
Did you do it ? It's that little blue thing😄😄
« Reply #33 on: May 11, 2014, 06:42:26 PM »
From memory the block fits onto the top of the accelerator pedal. You'll probably have to cut the top of the pedal to get the block into place.
finnie
« Reply #34 on: May 13, 2014, 06:33:21 PM »
Hi All
It`s nearly ready but just to check carb jets etc.
This is my current setup and was told they came from 2L engine:
32 Chokes
35 accelerator pump jets
155 Main jets
210 Aircorrectors
7772.10 emulsion tubes
60 Idle jets
7848.3 Aux venturis
What do other people have ? I was thinking to try it out first and then maybe a rolling road will tell me differently
Any advice would be appreciated
« Reply #35 on: May 13, 2014, 07:50:57 PM »
I got mine from Matt at Eurocarb can't remember the numbers now though. A rolling road session is always a good move. No point spending lots of money building an engine and then not getting the best from it.
« Reply #36 on: May 13, 2014, 09:09:48 PM »
How much is a rolling road session over the shuck?
finnie
« Reply #37 on: May 13, 2014, 10:01:21 PM »
No idea - but would expect something like ?150 +
finnie
« Reply #38 on: May 21, 2014, 04:02:46 PM »
Last update - ready to go 10 mm leads and normal speedo cable altered to fit carb side 😄
« Reply #39 on: May 21, 2014, 08:56:02 PM »
Looks the biz lad hope all goes well Wink
Pages: 1 2 [3] Go Up Print
