August 29, 2026, 03:28:41 AM
| | |-+  Simon's Abarth carb dilema
Author Topic: Simon's Abarth carb dilema  (Read 17352 times)
« Reply #15 on: March 23, 2014, 11:51:32 AM »
Hi ho simon , try the rolling road session on 30th see what actually your properly used  abarth is making , worn engine just poring fuel out the exhaust  Undecided
 Love the sound off twin carbs thats the problem you drive it different to get the sound , but the first half of a tank
 goes very quick , but drive like your mothers in the car with the second half i can get 33mpg as i had the 131 super as my daily driver with them on in the old days..
  Second choice that ive done twice is bore out the venturi on the adf , just like the ausi ford  falcon carb 34 adf made with bigger venturi , we,ve got 34mm chokes and 23 mm venturi ,   i bore them out to 25mm and 28mm  with a k/n type filter in the original pancake filter and force induction cool air feed .. Smiley Smiley
longhamrob
« Reply #16 on: March 23, 2014, 11:53:30 AM »
Correctly set up twin carbs with a 4 branch manifold should be noticeably more economical than standard.
Expect 24-25mpg against 21mpg.
They must be in perfect order which will require complete dismantling & rebuild.
Eurocarb will advise you on the correct choke size depending on application and can supply the relevant main jet, idle jet & if necessary,chokes.
The remaining jets & holders etc will probably be ok but note their values.
Parts individually do not seem expensive but multiply by 4 and include two gasket sets and your looking at a few hundred pounds.
When set up they are impressive to look at but more so to listen too even at idle which when tweaked correctly can be suprisingly smooth.
Both of my cars have drawn attention over their idling.
  It is worth noting that the noise (more noticably upon acceleration) penetrates the cabin whatever you try and will be too much for a majority of owners.
« Reply #17 on: April 01, 2014, 04:10:57 PM »
http://www.ebay.it/itm/Fiat-131-Abarth-collettore-per-carburatori-da-45-48-/371030353614?pt=Ricambi_automobili&hash=item566321e6ce&_uhb=1
 Roll Eyes
