October 25, 2026, 12:59:51 AM
| | |-+  cylinder diameter
Author Topic: cylinder diameter  (Read 17334 times)
simon abarth
« on: November 30, 2014, 11:29:05 PM »
 hi all,
anyone know how can we re-bore maximum LAMPREDI engine   Huh
then I go to 86MM? can I keep the original head gasket?
I hope your answers
pascal
( 84mm for departure ) Wink
TfP-Motors
999cc tbo
« Reply #1 on: December 01, 2014, 04:40:51 AM »
I have 85.5mm with orginal head gasket, but there are some tolerance in dimensions cylinder holes, so you have measure yourself gasket what you think use. Payen , Elring, Goetze are good manufacturers.
i have project motor with 86mm bore, but there i have flame rings, and not started engine yet...
also i been heard 87mm bore, but not seen it on action...
DIY -You know where problem is
simon abarth
« Reply #2 on: December 01, 2014, 04:17:58 PM »
thank you,
I think to be the maximum 86mm, I have heard many times,
I'll watch what you say to the cylinder head gasket
I own an engine block 82mm bore x 90 mm stroke
it will be good to do, where to 84x90 Other
I thought up pistons 86mm Opel GSI 16V (MAHLE) + 16V cylinder head fiat? must check the height of the piston / block
+ Compression ratio. should not be bad  Roll Eyes
the other answers are hoped to bore
simon abarth
simon abarth
« Reply #3 on: December 04, 2014, 12:38:59 PM »
no other answers Huh
« Reply #4 on: December 04, 2014, 02:48:59 PM »
this is an question for an engine builder!
he will give you the right answer.
simon abarth
« Reply #5 on: December 04, 2014, 07:06:50 PM »
yes it's true enzo,
is not to many requests about it  Undecided
but I expect guys like roger (toad)
I think it will have ideas of what  Wink
thank you
sdebez
fiat 131 gr 4.5
« Reply #6 on: December 05, 2014, 10:46:28 AM »
Can not remember where i read it, but I am lead to believe boring a fiat
Block to 86mm is more luck than judgement because you are getting
In to the area of tolerances during cast process.
Some blocks bore ok some don't, and some look ok until they have
Pressure on them.
So if it breaks in to the water jacket during boring heres the option of
Sleeving, which is what was done as a matter of coarse if going to 86mm.
This may need checking due to my foggy mind.
Sach
simon abarth
« Reply #7 on: December 06, 2014, 08:13:54 AM »
sach thank you, it is true what you say,
I would just use these pistons I have already (86mm)
and I will have new cylinder bore Roll Eyes
if some one have information other, I listen!
pascal
sdebez
fiat 131 gr 4.5
« Reply #8 on: December 06, 2014, 11:29:01 AM »
Hi
If you do go 86mm, and struggle for a head gasket there
Is the option of wills rings
Sach.
« Reply #9 on: March 22, 2015, 09:00:41 PM »
Hi
I believe the max size was 84.1mm due to class limitation ( 1999cc )
From experience : such modifications typically backfire, as the block needs to be greatly weaken ( 3 mm on each side.
I would not recommend it. My advice go for standard 84.
simon abarth
« Reply #10 on: March 23, 2015, 10:34:51 PM »
thank you for your answer Miro,
I'm still not at that level of preparation, but I'll watch it. TFP motors-have 85.5 on his, the Group A Lancia Delta turbo was 84.6 homologation ...
( with 8 valves )
pascal
« Reply #11 on: March 25, 2015, 10:15:50 PM »
hi all,
I hope your answers
pascal
There were many different block castings and therefore there are as many answers as block casting types. Going 2 mm larger seems like risky , but the only casting type i know well is the basic 124/131/132 casting type with 80 mm bore. I am not sure about the later block especially for non FIAT ( i.e. Lancia).
By the way it is easily measured just by inspecting the the engine block.
