July 28, 2026, 03:25:24 PM
| | |-+  Bored with the look of my 131 ?
Author Topic: Bored with the look of my 131 ?  (Read 17095 times)
« on: February 01, 2015, 10:53:45 AM »
Bored with the 131.time to get the angle grinder out on the springs , not the car. Lower it a couple of inches .
not on the flour like my first one with rock solid supension , only movement was the tyre sidewalls , ( Ah , youth )
« Reply #1 on: February 01, 2015, 04:37:29 PM »
 just need any junk springs to try on so i don't cut mine i can put it back if anything goes t*** up
« Reply #2 on: February 02, 2015, 07:57:09 PM »
Sorry Jason,
   Douglas says all old sta. Spring have been scrapped.
Sorry.
« Reply #3 on: February 02, 2015, 09:30:56 PM »
Any allready cut?
« Reply #4 on: February 03, 2015, 09:19:33 AM »
There were.
  The limit is damper bottoming and spring coming loose.
« Reply #5 on: February 03, 2015, 04:41:39 PM »
I can see big rust here...
« Reply #6 on: February 03, 2015, 07:35:04 PM »
Yep  Sad
strada
« Reply #7 on: February 10, 2015, 08:28:49 PM »
jason, jason, jason, if you want to improve the look of your car, firstly ditch those alloys an fit some proper fourleafclover sport wheels, (they are turning up on ebay quite a bit now).secondly, fit super bumpers an side cladding, then you will have a beautiful looking car.
 if you still insist on vandalisum, i do have springs but they are all in a pile, i cannot tell right/left/front or rear.
« Reply #8 on: February 10, 2015, 09:24:32 PM »
cheers strada i only want to lower the front a bit as its a bit nose high ..
« Reply #9 on: February 18, 2015, 07:12:23 PM »
Thought  id give these a try for a while instead  Grin
Good old wolfrace .. only 15" could have probably gone to 17"
« Last Edit: July 08, 2015, 10:12:43 PM by jasonh131 » Logged
« Reply #10 on: February 21, 2015, 08:17:54 PM »
 I like these   Grin Grin Grin  I'll stick with them
« Reply #11 on: February 22, 2015, 03:09:45 PM »
The swage line ( trim line ) down  the side  is only 71 cm at the front and 69.5 cm at the rear only 15mm diferance .and a massive 10 cm to arch from the front wheel what's yours ?
« Reply #12 on: July 08, 2015, 10:02:20 PM »
Finally got round to it a massive 65mm lowered ..
 Shocked Shocked
 looks so cool now  Cool Cool
none of the argenta type wafting anymore  , abit choppy but tolerable and handles great now round the corners  Wink
may be a bit less relaxing on the continetal trips , but nurbergring would be so good  or even spa 2016 ?
« Last Edit: July 08, 2015, 10:23:20 PM by jasonh131 » Logged
« Reply #13 on: July 09, 2015, 09:46:47 PM »
Now just needs under floor neons and a boom box!!  Grin
Actually that's quite low..do you have to avoid sleeping policemen?  Smiley
Yves
« Reply #14 on: July 10, 2015, 07:37:37 AM »
I like the lowered look, but those wheels... Huh
