June 25, 2026, 12:54:59 PM
| | |-+  ATS Classic wheel 13"
Author Topic: ATS Classic wheel 13"  (Read 5615 times)
mirafioriturkey
« on: November 16, 2016, 12:07:34 PM »
Hi,
I sell my wheel. From Turkey. If you want to buy, I send pm.
Yves
« Reply #1 on: November 18, 2016, 09:53:22 AM »
ATS are normally 4 * 100, no?
so one needs the specials adapting nuts to fit them to 4 * 98
mirafioriturkey
« Reply #2 on: November 18, 2016, 12:20:30 PM »
normally 4x100.
« Reply #3 on: November 19, 2016, 07:10:04 AM »
Note for Potential purchasers.
I believe most Fiat wheels are located using the central spigot and not the bolt holes. (Hub Centric)
Make sure that the central spigot and the locating hole in the middle of the wheel are a good fit.
I didnt! and had to have the wheel centres milled to the correct size, I then fitted wobble bolts and had no problems.
If the central hole is too large for the spiggot then you may have problems when tightening the wobble bolts and getting the wheel central.
Mirafioriturkey: have the wheels been fitted to a Fiat Previous? If so then ignore the above Grin
« Last Edit: November 19, 2016, 10:36:10 AM by parrish » Logged
