October 22, 2026, 11:02:11 AM
| | |-+  131 Abarth Group 4 Historic
Author Topic: 131 Abarth Group 4 Historic  (Read 18817 times)
Whiffy
« on: January 07, 2022, 06:37:29 PM »
 I have just started on the long journey, can anyone advise the following. In order to comply with Historic regs and in particular the 16v head can you use a 16Vv head from another car (Fiat/Lancia) providing the casting is the same as the original. Can anyone also advise which 5 speed gearboxes would comply.
« Reply #1 on: January 07, 2022, 07:00:58 PM »
I don't know for sure but I'd guess a 16valve head from a modern Lancia or Fiat won't be acceptable. Plus later heads had the inlet and exhaust sides swapped over. I suggest you contact Rallysport Developments http://www.rallysport-development.co.uk/ who will be able to advise you and also provide a brand new "historic" 16 valve head.
mick131
« Reply #2 on: January 13, 2022, 09:51:44 AM »
There is, somewhere out there, a video of a chap called Carlos and it shows his engine on start up with a reversed 16v head. Also on Guy Croft's site..
http://www.guy-croft.com/viewtopic.php?t=2416
Think the RSD heads are approx £4000 but could be wrong..
Mick Wilson
« Reply #3 on: January 13, 2022, 09:30:14 PM »
Yes, RSD 16Valve heads for the 131 are not cheap! But they are made in small numbers to the original specification. I also know that Guy Croft and others managed to fit newer 'reversed' heads to older twin cam engines but I wouldn't have thought that the car/engine would be homologated with historic status for racing. I think that's why RSD had to manufacture their own head to original specs to go historic racing. Then again I could be wrong as I am not an expert and just guessing.
