August 29, 2026, 01:45:38 AM
| | |-+  Fiat 131 and LSD ?????
Author Topic: Fiat 131 and LSD ?????  (Read 12049 times)
babos
Fiat 131 Racing
« on: April 23, 2008, 11:25:38 AM »
Any idea what you can put in the rear axel of 131 ? I know to put a real Fiat 131 LSD is hard to find.
Fiat 131 Racing - Fiat 131 2Door Serious 2.
« Reply #1 on: April 23, 2008, 04:43:40 PM »
How can you tell if its Lsd or not?
« Reply #2 on: April 23, 2008, 04:57:13 PM »
Jack up the back of the car with the handbrake off.
Turn one of the rear wheels by hand and look at the other rear wheel.
If the other rear wheel is turning in the same direction as the one being turned, you have an LSD.
If the other wheel is turning in the opposite direction of the one being turned, you have a normal differential.
markwilliams131
« Reply #3 on: April 23, 2008, 09:23:46 PM »
or a quicker way is lock the stearing wheel hard to the right
put her in first gear dial in 6 thousand revs and let out the cluch
if she goes around in circles it has a lsd  Cool
o id love an lsd  Tongue
« Reply #4 on: April 23, 2008, 09:50:59 PM »
I used to have an LSD in my Silver Sport and it was more trouble than it was worth! Having tried to keep up with the Stradales during some of the Rally stages we drove during last year's 3ma, I'd say having independent rear suspension is much higher on my list of "I'd love to have" for my 131.
« Reply #5 on: April 23, 2008, 09:59:15 PM »
i had lsd in Fib 1588 it would do circles until the diff locked up one fine day & had to fit a super back end cos the sport one was about 200 quid second hand. i got a spare backend with my car, i wonder?
babos
Fiat 131 Racing
« Reply #6 on: April 24, 2008, 11:39:49 AM »
What a friend told me is to get an english axel ( escort mk1 or mk2 ) and use this. By cutting the 131 diff and the english diff and make one. But here in malta they use the 131 diff with argenta shafts because it can handel more power than the english diff. Maybe if you use a atlas diff will be better ? Any suggestion ? Or a different diff that it is easy to find with LSD ?
hicky131
The future's bright - The future's orange
« Reply #7 on: April 27, 2008, 08:50:44 PM »
Hi there.
If you can get hold of an atlas axle,that would be the best choice as they are stronger than the english type ones.
All the Escort rally boys use them and the lsds are easily available for them.
I have a chopped up 131 axle on one of my cars with an english diff casing in the centre as you've mentioned,but i cannot say how strong this setup is because the car has been in storage since i bought it.
If the setup on mine is no good when i finally get around to working on the car,i'll be going the same route as Mick131 on here and doing a BMW independant conversion. Those are strong diffs and can take alot of abuse.
Get one from a 325i sport though,as they have the lsd fitted as standard. Smiley
Cheers,
Wayne.
Wayne Hickman,
Huddersfield,West Yorkshire, UK
