Title: wheels Post by: MF 131 on June 27, 2008, 12:48:58 AM Hi ,Wanting to use 100 PCD 14 inch wheels on 131/124 .Don't really want to use wobble bolts. Any help would be appreciated. Cheers Gary
Title: Re: wheels Post by: Testament on August 25, 2008, 08:50:27 AM it depends on the wheel design, but if there is enough meat you can get the holes drilled out to a larger diameter in a 98mm PCD and then have sleeve inserts fitted wo bring the hole size back to normal.
Also make sure they centre on the hub - you can get centering rings if the wheel hub bore is larger. have you got a set of wheels in 4x100? or just looking at what options there are to fit 4x100 to give more selection? Title: Re: wheels Post by: MF 131 on August 25, 2008, 09:57:39 PM Hi No just looking at some 14 inch that would suit. Have 9 Cromos all 13 inch. Whats your number so we can have talk . Cheers Gary
