Title: cam belt Post by: finnie on September 21, 2011, 09:32:48 PM Hi All
I need a cam belt for my rebuild 1.8 TC - any idea where to get one from ? Do you have a belt no. ? How long is it and how many teeth ? Thanks Finn Title: Re: cam belt Post by: mirafioriman on September 21, 2011, 09:40:17 PM Try your local motor factors. Not sure about the 1.8 but I used to get 2 litre ones by Gates pretty easily recently.
Title: Re: cam belt Post by: Sev131 on September 21, 2011, 10:06:14 PM Hi Finn
Whereabouts are you? I have a brand new Gates Belt. Title: Re: cam belt Post by: Tas131 on September 21, 2011, 10:24:22 PM 2 litre belt is 148 teeth, 1800 is 146 teeth.
Gates Timing Belt T020 Belt Specification: Neo 146x19 T Title: Re: cam belt Post by: finnie on September 22, 2011, 11:51:56 AM Hi Finn Whereabouts are you? I have a brand new Gates Belt. North London ;) Title: Re: cam belt Post by: finnie on September 22, 2011, 09:47:13 PM Hi All
Managed to get the 146 teeth belt but it`s a little to big so will try the 144 tomorrow ! I thought the 1.6 and 1.8 TC was the same block and head but it`s not !!!!! Maybe my engine isn`t a 1.8 after all :'( Title: Re: cam belt Post by: mirafioriman on September 22, 2011, 09:57:08 PM Perhaps it's a 1.6? The bore was the same I think. I know the two litre is definitely taller than the 1.6, not sure but the 1.8 must be in the middle?
I did own a 1.8 twin cam once (fitted in a 132 1800 ES) but I have sold that now. Title: Re: cam belt Post by: finnie on September 22, 2011, 10:07:53 PM Think the 1.6 and 1.8 have the same stroke . Difference must be in the head ! I`m confused -will do some reading in the weekend on my boat ;)
Title: Re: cam belt Post by: Tas131 on September 23, 2011, 09:07:41 AM Hi All Managed to get the 146 teeth belt but it`s a little to big so will try the 144 tomorrow ! I thought the 1.6 and 1.8 TC was the same block and head but it`s not !!!!! Maybe my engine isn`t a 1.8 after all :'( What's the number stamped into the block near the oil filter housing, that will tell you what your engine is. If the belt is just a bit too big, you could have the wrong idler bearing, there are 2 different sizes available but it's not often mentioned. IIRC the 1.6 and 1.8 blocks are the same height, the bore was increased from 80 to 84mm, but the bores had to be offset to allow for the increased diameter. Which is why the valves aren't aligned with the center of the bore on 1 & 4. Title: Re: cam belt Post by: finnie on September 23, 2011, 01:48:08 PM The bore is 84mm and number on block is 132 CB 0A0 the idler bearing is 71mm :)
Thanks Title: Re: cam belt Post by: mirafioriman on September 23, 2011, 06:51:50 PM After some research:
The 1585cc, 1756cc and 1995cc twin cams all have an 84mm bore. The stroke is different between them, 1585cc is the shortest, 1995cc the longest. Twin cams were available with a different bore size but these are fitted to other models such as the 124. In the UK the 131 was available with the 1585cc and 1995cc twin cams, although I did see a 1300 T/C 131 once I think, although I was a child at the time so I could be wrong ::) In the UK the 132 came with a 1756cc and 1995cc twin cam. It also came with a 1592cc engine with an 80mm bore, I've not seen / owned one but perhaps it was available in the UK. As you bought new 84mm pistons it must be an 84mm bore engine and therefore a 1585cc, 1756cc or a 1995cc engine. The stroke options are therfore: 71.5mm, 79.2mm or 90mm Title: Re: cam belt Post by: sdebez on September 23, 2011, 09:06:42 PM i can take some measurements if it helps i have an 1800 and 2000.
sach Title: Re: cam belt Post by: mirafioriman on September 23, 2011, 09:14:21 PM I would be interested on how the measurements differ between an 1800cc and a 2000cc engine :)
Title: Re: cam belt Post by: finnie on September 25, 2011, 09:34:46 PM I would be interested on how the measurements differ between an 1800cc and a 2000cc engine :) I`ll measure the stroke monday - then I will know what it is ;) Title: Re: cam belt Post by: finnie on September 26, 2011, 09:04:28 PM Hi all
Measured the stroke today it was 73 mm with a bore of 84 mm and domed pistons - and the 144 teeth belt fitted perfect . I`m very confused now Title: Re: cam belt Post by: mirafioriman on September 26, 2011, 09:11:27 PM Looks like it is a 1585cc twin cam then. These did have domed pistons whereas the 1995cc had flat top pistons. Not sure what the 1756cc engine had piston wise.
Title: Re: cam belt Post by: Tas131 on September 27, 2011, 11:14:27 PM The bore is 84mm and number on block is 132 CB 0A0 That's just the number cast into the block, it doesn't tell you much. The engine number is stamped into a flat surface near the oil filter or fuel pump. Title: Re: cam belt Post by: finnie on September 28, 2011, 08:41:18 AM Ok found it now ;)
engine no. 131 P1 000 1021751 - I bought it as a 1800 from a kit car but everything points towards a 1600 >:( Just have to rebuilt my 2L instead ;) Title: Re: cam belt Post by: Tas131 on September 28, 2011, 10:40:30 AM 131 P1 000 Are you sure it's not B1? 131B1.000....1585 (84 x 71.5)....95 / 98....- Supermirafiori 1600 ('78...82) http://www.netikka.net/ville.vieri/tc/tclist.htm Title: Re: cam belt Post by: finnie on September 28, 2011, 11:49:32 AM look at them data -yes it`s a B1.
thanks for that link . 2L block is on it`s way to my engineer ;D |
