Title: brakes Post by: Andy c on June 29, 2007, 07:25:07 PM when out jollyingin the car it started pulling to the left so trip back to work i find the o/s/f caliper
seals gone,so to keep me mobile i fitted the one off the rust bucket(knowing it could be just as bad after been standing around for a few years) but worth a go,it lasted about half a hour. so i am in need of a o/s/f caliper can anyone help. was also thinking about up rateing the front brakes has anyone any ideas on this. Title: Re: brakes Post by: Tas131 on December 18, 2007, 11:08:34 AM 6 months late on this one, but don't you blokes rebuild your calipers? Seal kits are readily available over here. I put a set of regatta 100S discs and calipers on mine, 257mm diameter instead of the standard 240mm (I think). A banjo bolt from the regatta rear caliper is required to fit the 131 brake hose to the regatta front caliper as the 131 banjo bolt thread pitch is different. The regatta calipers bolt straight up to the 131 stub axle and the fiat spacer plate is not required to get the same wheel offset. It all cost me about $350 I think, for new discs, second hand calipers, new seal kits and a set of EBC greenstuff pads. It improved the front brakes a huge amount, a downside though is 13" wheels will no longer fit.
Cheers, Mick. Title: Re: brakes Post by: parrish on December 18, 2007, 02:05:47 PM Fiat Uno Turbo Calipers and disks are a straight forward swop.
Easier to get spares. Same problem as the Regatta option, the front standard 13" rims wont fit, im not too sure what the clearence problems really are but a thin spacer may be a solution. Steve Title: Re: brakes Post by: Tas131 on December 18, 2007, 08:48:34 PM Fiat Uno Turbo Calipers and disks are a straight forward swop. Easier to get spares. This would have been my preferred option, but we didn't get the Uno over here. I could have got an Uno setup from New Zealand, but it would have cost more and then freight across the ditch on top. |
