April 26, 2024, 07:45:26 AM
| | |-+  131 Sport wheels
Author Topic: 131 Sport wheels  (Read 24662 times)
curt
« Reply #15 on: May 07, 2007, 09:25:24 AM »
hi theo
found loads of original cromadoras on ebay italy but all 13 inch
In my search i came across these that were similar to the lancia beta ones i had fitted -cheap as well at the moment-dont know if they are of any interest
will keep on looking  Smiley
http://cgi.ebay.it/Cerchi-in-lega-14-pollici-4-fori-per-FIAT-ALFA-LANCIA_W0QQitemZ290112077086QQihZ019QQcategoryZ72249QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Solihull West Midlands
« Reply #16 on: May 07, 2007, 10:06:20 AM »
Thanks for the link. I am not sure they'll suit the 131 and I suspect postage from Italy will make them prohibitively expensive.
« Reply #17 on: January 21, 2018, 04:24:29 PM »
This is where it all
 went wrong  Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy
« Reply #18 on: January 22, 2018, 02:41:21 AM »
You've dragged up a very old post Jason!  Shocked Roll Eyes
I think I'll go back to the darker grey "steel" colour though as the silver is too light....  Undecided
Kiwi131R
« Reply #19 on: January 23, 2018, 06:33:40 PM »
I am no expert but on the plus side I believe the Lancia Beta rims are 14", 4 x 98 and magnesium alloy making them very light. On the negative side they are a front wheel drive not rear wheel drive offset.
« Reply #20 on: January 24, 2018, 12:59:17 AM »
Correct on all counts!  Wink  The wheels are extremely light magnesium alloy and they are 14 inch and 4x98pcd so a straight fit on the Fiat 131. My car is fitted with the larger discs (and callipers) from a Fiat Bravo so 13 inch wheels won't fit, they must be 14 inch (or larger). To counteract "the negative side" of the incorrect offset, the wheels are mounted with solid alloy 8mm spacers. But that creates another problem as the rear hub-centric ring is just 8mm so with the spacers fitted the wheel effectively sits flush on the hub and spacer. Perhaps I should have replaced the wheel bolts with studs and nuts but I decided to use high tensile steel bolts instead.
« Reply #21 on: February 20, 2018, 08:22:35 PM »
Still need a bit of a deep dish  Roll Eyes Roll Eyes
