October 23, 2026, 12:42:39 PM
| | |-+  130 help needed!
Author Topic: 130 help needed!  (Read 8619 times)
« on: May 11, 2008, 07:11:46 PM »
Does anyone know which cylinder is which? The distributor cap is numbered, but not the cylinders.
131v6
« Reply #1 on: May 12, 2008, 06:44:38 AM »
Cylinders numbers are cast (quite small!) into the outside face of the cambox just below the cambox cover gasket above each cylinder. I'm pointing at the location of number two marking in the photo.
Looking from front its 123 up left bank (front to rear) and 456 up right bank front to rear. Firing order is cast in right cambox cover,
2 Dr 131 3.2, 124 Special 2.0 turbo, 850 Coupe 1.4, 850 Sport Coupe, Coupe 20VT Plus, Grande Punto Sport....and a couple of projects Smiley
Christchurch, New Zealand
« Reply #2 on: May 12, 2008, 11:53:02 AM »
Thanks,
Just what I needed, should get it sorted tonight!
