October 23, 2026, 11:35:30 PM
| | |-+  wheels
Author Topic: wheels  (Read 8137 times)
MF 131
« on: June 27, 2008, 12:48:58 AM »
Hi ,Wanting to use 100 PCD 14 inch wheels on 131/124 .Don't really want to use wobble bolts. Any help would be appreciated. Cheers Gary
Testament
« Reply #1 on: August 25, 2008, 08:50:27 AM »
it depends on the wheel design, but if there is enough meat you can get the holes drilled out to a larger diameter in a 98mm PCD and then have sleeve inserts fitted wo bring the hole size back to normal.
Also make sure they centre on the hub - you can get centering rings if the wheel hub bore is larger.
have you got a set of wheels in 4x100? or just looking at what options there are to fit 4x100 to give more selection?
MF 131
« Reply #2 on: August 25, 2008, 09:57:39 PM »
Hi No just looking at some 14 inch that would suit. Have 9 Cromos all 13 inch. Whats your number so we can have talk . Cheers Gary
