September 14, 2026, 04:33:33 PM
| | |-+  LSD and anti-roll bar from lada into 131 rear axle?
Author Topic: LSD and anti-roll bar from lada into 131 rear axle?  (Read 10455 times)
« on: January 17, 2009, 11:41:05 PM »
i've been fiddling around with my lada past few days, and i've got some ideas concerning my 131. the rear suspension is very simmilar.
i've fitted a lsd and rear anti roll bar and i'm wondering could it be fitted into/onto 131 rear axle?
« Last Edit: January 17, 2009, 11:45:29 PM by djape1977 » Logged
« Reply #1 on: January 17, 2009, 11:49:07 PM »
on some of these pics you can (more or less clearly) see a lada (fiat 124) diff. is it same as on 131?
several questions youre bound to ask me:
yes, russians do make an lsd for lada, there's a 180mil. people there, lots of snow and rwd cars...
rear antiroll bar also. some of them apparently race their ladas
no, i didn't drive it yet, too much snow and summer tyres do not mix well
« Last Edit: January 18, 2009, 12:10:59 AM by djape1977 » Logged
« Reply #2 on: January 18, 2009, 01:53:30 AM »
and here's lada rear axle, one from 132 gls and a 131 one. simmilarities and diferences...
« Last Edit: January 18, 2009, 01:56:27 AM by djape1977 » Logged
« Reply #3 on: January 18, 2009, 08:19:03 AM »
I used to have Lada rear axle with LSD in my FSO Polonez with 2.0l DOHC engine. I have cut all the mounts from lada axle and welded to that diff mounts from FSO polonez. it was all fine but i had to use a bit longer rear part of driveshaft(i am not sure but it could be lada- it was long time ago).
The main problem was not with fitting the diff but the ring and pinion gears did not last any longer than about 3 weeks(i changed them every rally as it simply was destroyed), that is why i have decided to fit the lada LSD into FSO Polonez axle. I had to make new LSD housing, i took all internal parts from Lada LSD and fitted it into a casing that had all external dimensions like FSO Polonez, this required me to use lada driveshafts as the spline was smaller in diameter than FSO. The axles required a bit of modification but nothing too difficult to do. After that change i was able to use 4,55 ring and pinion from FSO Polonez Truck which is widely available in Poland.
If that LSD that you use is a plated one then it is very reliable unit and i used it for many years with almost no problems(once i just had to TIG weld the spline for clutch plates to the gear as the connection broke(looked like some press fit that let go).
« Reply #4 on: January 18, 2009, 11:45:59 PM »
a mythical rear anti-roll bar from fiat argenta TD and Volumex
