September 14, 2026, 05:31:52 PM
| | |-+  fiat 132 servo brake unit modification
Author Topic: fiat 132 servo brake unit modification  (Read 8123 times)
« on: February 12, 2009, 10:39:17 AM »
i want to install servo brake unit from 132 1800gls into my twincam lada. they're almost the same except for the bit marked red on the pic (upper one is from f132 and lower from lada). i do not want to cut and weld it, i don't think its smart to mess around with that. anyone ever tryed to remove that part fom servo unit? is it possible?
also, master brake cylinder from fiat 132 is much bigger than on lada. does it mean it pushes more oil? higher brake pressure? any ideas?
« Reply #1 on: February 12, 2009, 10:58:54 AM »
by the way, i'm in the process of swaping the engine, for a bigger one ofcourse? Grin
« Last Edit: February 12, 2009, 11:01:31 AM by djape1977 » Logged
« Reply #2 on: February 15, 2009, 09:48:03 AM »
ok guys, thanks for nothing  Angry , problem solved. i cut and welded what i needed...
