July 26, 2026, 10:43:58 AM
| | |-+  head with twin carbs & dizzy
Author Topic: head with twin carbs & dizzy  (Read 12549 times)
« on: March 04, 2009, 11:00:53 PM »
131 sport head fitted with cam driven distributor & twin downdraft carbs not in the best condition anyone interested in this?
« Reply #1 on: March 04, 2009, 11:03:53 PM »
more pics
bolger
« Reply #2 on: March 05, 2009, 03:43:56 AM »
pm sent
« Reply #3 on: March 05, 2009, 07:09:47 PM »
i think i could use it. price? airbox to go with those carbs?
« Reply #4 on: March 05, 2009, 07:19:32 PM »
Sid , I could  use the rubber seals  sitting on the top of the carbs ... Any chance for those ?
« Reply #5 on: March 05, 2009, 08:46:36 PM »
Hi Miro i am going to hold on to this set up they are 44 idf carbs so going to look in to getting them rebuilt & maby fit the other engine i have with the dizzy drive option on the cambox ( not the one in the pic)
mclements131
« Reply #6 on: March 05, 2009, 09:03:03 PM »
hiya can. itrsested in choak daifram and aslo venturyf  frind in drogeda can colect sunday annd cam seels block [ [ isolator housing ]] cheers martin dissy drive worm gr ger gearar
124AC
« Reply #7 on: March 06, 2009, 08:02:26 PM »
All
I have two sets listed on eBay at the moment.
Set 1:  Original 124 setup in good condition.
Set 2:  Waffle manifold and a pair of IDFs from an Alfasud.
Duncan
« Reply #8 on: March 06, 2009, 09:35:11 PM »
sid131 are these for still for sale or did you change your mind ....
 and how did you get hold of some 44 idfs
« Reply #9 on: March 06, 2009, 09:40:35 PM »
All
Set 1:? Original 124 setup in good condition.
Set 2:? Waffle manifold and a pair of IDFs from an Alfasud.
Duncan
can you post the ebay links please.
« Reply #10 on: March 07, 2009, 01:49:48 AM »
Sid
I will have soon a full set I will want to sell:
- waffle manifod,
- two  fully professionally rebuild 40 IDF's DCOE (downdraft) webers
- original 124 turtleback air box
PS: I take the rubber seals are a "no go"?
« Last Edit: March 07, 2009, 09:56:13 PM by miro-1980 » Logged
bolger
« Reply #11 on: March 07, 2009, 02:22:05 AM »
Weber DCOE are sidedraft carbs ...
« Reply #12 on: March 07, 2009, 09:55:24 PM »
WELL, THAN SOMEONE REALY READS THIS   Grin
(THANKS bolger , I  CORRECTED THE OBVIOUS MISTAKE)
MIRO
PS:  look at this . This should be fairly low priced ...
http://131mirafiori.com/smf/index.php?topic=2045.0
« Last Edit: March 08, 2009, 11:29:48 AM by miro-1980 » Logged
