September 12, 2026, 04:45:02 PM
| | |-+  wanted series 1 rear lights and rear panel
Author Topic: wanted series 1 rear lights and rear panel  (Read 9052 times)
maxi.man
« on: May 09, 2009, 08:45:14 AM »
has anyone got any can trade  parts from a 131 racing or cash ??  also wanted new front panel
« Reply #1 on: May 09, 2009, 09:06:26 AM »
Hi maximan - The S1 lights are all over Ebay, UK, France, Italy, Germany - Should be easy enough to find & buy.
Also here is a front panel...Not sure how you go about buying this though...?
http://www.subito.it/rivestimento-anteriore-fiat-131-trapani-5657795.htm
Lights from the same website but same comments apply...
http://www.subito.it/fanali-post-fiat-131-mirafiori-trapani-4959989.htm
maxi.man
« Reply #2 on: May 09, 2009, 09:07:57 AM »
thanks  Wink
chris131
« Reply #3 on: May 09, 2009, 10:08:05 AM »
pm sent
Yagmur
« Reply #4 on: May 09, 2009, 06:52:09 PM »
I have some rear panels and rear lenses.
« Reply #5 on: May 09, 2009, 09:06:49 PM »
Here you go, on Ebay in Italy. Reasonable postage to the UK too, although the picture is not too good.....
http://cgi.ebay.co.uk/FIAT-131-ABARTH-traversa-posteriore-nuova-originale_W0QQitemZ280343755414QQcmdZViewItemQQptZRicambi_automobili?hash=item280343755414&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A10%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
kkkango
« Reply #6 on: May 11, 2009, 03:09:05 PM »
Hi, I  brought a pair of E bay rear lights as I have original 131 lights on my kit car although they are basically the same the printed circuit board connector is a lot longer than the original 131 lights I had.
to overcome this I had to drill out the rivets and remove the circuit board so I could solder wires on then put screws in to remount the boards,  cut my loom ends plugs off and fit joining terminals.
I suppose you could always swap the circuit boards from your old lights if the connectors are different and your boards are good.
