October 23, 2026, 08:42:07 PM
| | |-+  RS 911 aluminum calipers - help needed
Author Topic: RS 911 aluminum calipers - help needed  (Read 12329 times)
« on: May 18, 2009, 08:52:23 PM »
Guys,
I was told you can put the RS 911 calipers into standard 13" wheels on 131.
Anybody had the experience in actually doing it ?
Before I spend 600 euro for the calipers I would like to know of there are any mounting/ use  issues ?
wak131
OOo ///// oOO
« Reply #1 on: May 18, 2009, 11:15:23 PM »
That?s heavy, recently i was testing if a Tipo 2.0 16V front calipers for ventilated 257mm discs would fit into the original Supermirafiori 14" wheels and they rub the wheel a bit. The non-ventilated variant will fit nicely. I Would like to see how a 911 calipers would fit into a 13 inchers... anybody knows more?
alan.acs
« Reply #2 on: May 19, 2009, 06:31:01 PM »
Fiat used thease capliers on some of the 131 abarth rally cars as well as ap capilers.
but they where always on 15" wheels.
« Reply #3 on: May 19, 2009, 11:58:06 PM »
Ok, so what do I do for 13 " wheels ?
Any ideas ?
wak131
OOo ///// oOO
« Reply #4 on: May 20, 2009, 09:56:59 AM »
Uno Turbo use 240mm ventilated discs in 13" wheels.
Look here http://www.trademe.co.nz/Browse/Listing.aspx?id=50093718
I?m not quite sure what modification to the caliper mounting is needed if any.
« Reply #5 on: May 21, 2009, 09:40:08 PM »
Wak131 - Thanks a lot ! Most useful info!
T
hanks I will investigate it  and report on the web , so this is tested as to what can be done with the uno turbo brakes application for the 131.
« Last Edit: May 21, 2009, 09:42:00 PM by miro-1980 » Logged
« Reply #6 on: May 23, 2009, 12:29:23 AM »
Uno T brakes bolt straight up to a 131 apparently, I looked into it a few years ago but considering we didn't get the Uno in OZ I ended up using regata calipers and larger discs. 13" wheels won't fit my car now. A bit more info here!
http://www.turbo124.com/forum/viewtopic.php?f=3&t=864&start=0
« Reply #7 on: May 23, 2009, 06:36:55 AM »
Honda civic vented discs(257mm) with calipers will fit into 13" wheels. I used to have such setup in my FSO Polonez rally car some time ago.
