October 23, 2026, 07:43:46 PM
| | |-+  Heater control panels
Author Topic: Heater control panels  (Read 12863 times)
« on: June 04, 2009, 08:03:39 PM »
From a LHD Fiat 131.
From a RHD Fiat 131
« Reply #1 on: June 04, 2009, 08:40:14 PM »
Is this the required part...?
« Last Edit: June 05, 2009, 06:55:30 PM by kev131 » Logged
brensport
« Reply #2 on: June 04, 2009, 08:59:35 PM »
KEV I CANT MAKE OUT FROM DA PICTURE WHICH SIDE DA CONTROLE CABLES FROM DA BOX CONNECT  ARE THEY LEFT OR RIGHT
« Reply #3 on: June 04, 2009, 09:25:07 PM »
Shall I take another photo from the back..?
brensport
« Reply #4 on: June 05, 2009, 06:43:25 PM »
Hello KEV i think we need expert advice here because even on rhd cars there can be differences between them so if anyone has any knowledge of these let us know here. We are looking for 1 for a lhd car
jseabolt
« Reply #5 on: June 07, 2009, 03:30:36 AM »
Your lucky! I'd love to have a cable operated system on my 131.
US spec X 1/9s and 131s had vacuum operated ventilation controls most likely because most if not all had air conditioning and the diaphrams bust when they get old. Usually the defroster canister busts and all the air diverts toward the windscreen and no air hits the floor.
To "fix" my 131 I broke the diaphram off the defroster. I'm going to connect the acuator with a choke cable.
Now with the defroster vent closed, the air is diverted toward the floor however once the dash vents are open most of the air comes out the vents so I think this will work without having to remove the dash and try to source new vacuum canisters.
Since FIAT underestimated our hot humid climate and used an undepowered system, I have no plans on trying to get the original system functioning. I'm hoping to retrofit a R132a compressor from a Chyrsler minivan as well as the condensor and dryer. Mainly because Mk1 models(~1994) were V-belt driven.
Hopefully the originally evaporator will be sufficient. I don't know it's worth a shot. The plumbing and wiring is all there.
1981 Trabant 601
2003 Subaru Baja
« Reply #6 on: June 17, 2009, 06:20:35 PM »
Well I don't quite have one either...yet!? Wink
Bren - This is available on Ebay - Does it look like it will fit? - It's from a Fiat Brava (in the USA) so should be LHD.
brensport
« Reply #7 on: June 17, 2009, 06:49:42 PM »
yes Kev it looks right but turn it up the other way so i can see da top end
« Reply #8 on: June 17, 2009, 08:29:19 PM »
I have not bought it yet Bren although it's only a few dollars - I'll get it for the service in 2010!  Wink
