September 14, 2026, 07:28:09 PM
| | |-+  Fiat 131 calipers
Author Topic: Fiat 131 calipers  (Read 19076 times)
cypriot
« Reply #15 on: February 03, 2014, 05:59:31 PM »
Re 257
All is required is a different mounting bracket - one for 257's. I am not sure this was actually from Uno Turbo ( probably Tipo/Tempra) but it fits  The calipers are the same just the brackets are larger.
I will test a set on July 6/7 and tell you the result Huh??
Sorry for digging an old thread but I also moving same direction. I noticed that it is very easy to source Tipo / Tempra 2.0 16v etc 257,5mm  diameter front rotors for reasonable price about 30 euros a pair (new)
Now I am after front left / right calipers to use with these rotors. I haven 't searched yet but it must not be to hard to find new calipers
Have you use these setup ?
How hard to fabricate mounting brackets to fit them fiat 131 .
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
H?rmann Intake Manifold
Weber 40 IDF Carbs
GC Spec FW
