October 23, 2026, 07:43:46 PM
| | |-+  Need help: gerabox to shaft Need help: gerabox to shaft flange!
Author Topic: Need help: gerabox to shaft Need help: gerabox to shaft flange!  (Read 10131 times)
« on: June 22, 2009, 01:12:25 AM »
Guys!
I need the part (name?) connecting the 5 gearbox to the flexible shaft support
Again neither my English nor technical knowledge suffice.
I need answers to three questions:
1/ What is its proper (customary)? name in English?
2/ Were there different ones depending on engine size / production year?
3/ Will this this one fit?
http://cgi.ebay.pl/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=150353361396?
gunobla
« Reply #1 on: June 22, 2009, 05:36:54 AM »
I have always called the part "the Yoke".  I can't tell you if it will fit or if different models have different yokes
« Reply #2 on: June 22, 2009, 07:58:07 AM »
I've always referred to them as a yoke. I'm only aware of 2 types for 131 5 speeds, the type that is bolted to the gearbox output shaft and fits the rubber donut and a sliding type that I can't remember if they use the donut or not. Do you not have one that you could remove to compare with the photo?
« Reply #3 on: June 22, 2009, 08:37:15 PM »
Good idea ; Grin
Will take a look at mine first ...
« Reply #4 on: June 26, 2009, 12:57:19 PM »
Hello Miro,
this is the Original FIAT Part Nr. 4328317  131 Sport/Racing 5 Speed Box flange!
Enzo Wink
« Reply #5 on: June 26, 2009, 09:12:02 PM »
as tas131 said, there's two types, one is fiat 131, 132 and argenta and other type is the same as on any rwd lada (probably 125p too?) which should be easy to obtain in your part of the world.
how come you need that? did you menage to destroy it? how?
p.s.
sorry about that 132 sway bar, still had no time to check out which ones do i have
