October 23, 2026, 07:43:46 PM
| | |-+  Power steering rebuild kit wanted
Author Topic: Power steering rebuild kit wanted  (Read 14318 times)
« on: June 29, 2009, 09:02:51 PM »
I need to rebuild my power steering rack as i have some leaks on input shaft. Does anyone kno where can i get all 4 seals(2 for input shaft and 2 for output shaft). I tried in my local shop with such things and they had none in stock but will try to locate it so if i get them i will be able to supply it later but in case somebody knows where to get such kit then i will be happy to buy it. It needs to be high pressyre seals.
I am also willing to rise pressure a bit in my power steering as with 1,7turn lock to lock it is not that easy to turn the wheel(not too bad but it can always be better). Hopefully fitting a bit stronger spring or a washer on the original one in relief valve in pump will do the job. Has anyone made it with success?
« Reply #1 on: June 29, 2009, 10:25:41 PM »
Have a feeling you will have to try a seals specialists as Fiat never really sold internal steering rack parts but if it is any help Lucas do a power steer stop leak and it is very good as I had to use it 6 years ago in my Thema as the rack was well over 1000 euro and never saw the leak again.....
« Reply #2 on: June 29, 2009, 10:37:54 PM »
Tomek, get a new one from Yagmur !!!
« Reply #3 on: June 30, 2009, 05:07:24 AM »
There is no need to get a new one as it is all in pefect condition except the sealings that will cost probably no more than about 30 euro and you get a steering rack like new.
« Reply #4 on: June 30, 2009, 11:42:31 AM »
Have you tried contacting TRW (www.trw.com) who make the racks for the 131? In the UK, Power Steering Services (http://www.power-steering.co.uk) are very big and very good at reconditioning Power Steering Racks. Normally they will offer an exchange or recondition service for your rack but they may be able to supply the kit for you. Incidentally, the same TRW racks as on the 131 are used on the Maserati Biturbo (pre 1988) so try your local Maserati dealer!? Grin
« Last Edit: July 01, 2009, 12:27:02 PM by Thotos » Logged
« Reply #5 on: June 30, 2009, 04:55:03 PM »
If that is the case Theo would David Eskew be worth a try as he might even know where the internal parts could be sourced from....
« Reply #6 on: June 30, 2009, 08:52:56 PM »
I called power steering today and they will let me know whithin about a week if they can get it. If someone has any news about seals then let me know. I will try to make pictures tommorow with dimensions so maybe it will help.
« Reply #7 on: June 30, 2009, 09:01:02 PM »
David Askew (http://web.onetel.net.uk/~davidaskew/maserati/index.htm) started off as a used parts service (he broke a lot of old Biturbos for parts) but now also offers a refurbishment service so might be worth a call to ask if he knows where to get the repair kits from.
« Last Edit: July 01, 2009, 12:25:14 PM by Thotos » Logged
« Reply #8 on: July 01, 2009, 11:00:29 AM »
I got an email from Dave Askew that he can supply rebuild kit for 30GBP. I will order it and let you all know how the rebuild went. Thanks for help.
