September 14, 2026, 12:22:07 PM
| | |-+  131 power steering
Author Topic: 131 power steering  (Read 5820 times)
« on: August 28, 2009, 02:51:53 PM »
Is anybody after power steering rack, pump & reservoir for 131 supermirafiori, ?60 the lot
chris131
« Reply #1 on: August 28, 2009, 05:08:23 PM »
Yes i would be, if the postage isn't to expensive. The steering on my sport would pull the arms out of ya.
If you could find out how much UK postage is and let me know?
thanks
« Reply #2 on: August 28, 2009, 05:41:03 PM »
Chris are you in uk ? as postage would be a pain, prefer it if you picked them up. All these bits were off a Y reg supermirafiori that I dismantled 10 or more years ago and was A1 when removed and cant see why there would be a problem now but thats why Ive put it up for ?60. Also be aware that if your car is a mk3 131 cl etc then there wont be a problem converting it to power steering but if mk2 I think from memory you will need to change cross member to mk3 type & engine mounts different to clear rack also track control arms longer as I recall. David
« Last Edit: August 28, 2009, 05:44:31 PM by david » Logged
