September 16, 2026, 01:00:45 AM
| | |-+  Starter motor question
Author Topic: Starter motor question  (Read 9065 times)
cooter131
/1/3/1/
« on: October 19, 2009, 06:01:05 PM »
Hello all,
I ve been reading this forum some time now but never posted since I was busy reading all of the posts here from the very beginning.
I guess it's about time I make a start.
I own a 1600 Mirafiori special with only a few modifications (twin Webers, somehow lowered and alloy wheels)
I recently discovered one unwanted modification (by the PO probably).
The starter motor sometimes fail to engage. It hits on the flywheel and after a couple of tries it starts the engine. It is not the solenoid as I first thought.
After removing the starter motor I found it's got 11 teeth.
Is that the correct one? It is a Bosch (and not Magnetti Marelli like on my previous 131 special 1300).
Oh, by the way, the engine is 125BC 000 1600 and not the original 1300cc. (also changed by the PO).
Thanks in advance,
George.
George K.
Athens, Greece
« Reply #1 on: October 19, 2009, 07:04:31 PM »
I am not sure but i think it should be 9 teeth.
« Reply #2 on: October 20, 2009, 07:48:14 AM »
Hello,
Only 1300 ccm has 9 teeth.
Fiat 125 and 124 Engines
125A.000, 125B.000, 124BC.000 with 1608 engine has 11 teeth.
Fiat 124 Spider 1,4 1,6 1,8 2000
132 131 125 Argenta  allso 11 teeth.
Enzo Wink
« Reply #3 on: October 20, 2009, 09:13:07 PM »
hi
 have you check the teeth on the fly wheel ring gear ,are they worn on the edges or missing teeth ,
if its happen before , the stater motor would have been replace but never the ring gear and the new starter motor then get chewed up in a while again.
jason
cooter131
/1/3/1/
« Reply #4 on: October 21, 2009, 09:02:08 AM »
Thanks a lot guys.
At least I now know the starter motor is the correct one.
About the difficulty to engage I also start to believe that it should be the flywheel.
There is a gap from where I can check its surface while cranking.
I 'll do that and come back with news
George K.
Athens, Greece
